Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
Sunroof Solution to noise / sticking - Lube it
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 05-15-2019, 04:25 PM
GrantGunderson
GrantGunderson is offline
GrantGunderson is starting off with a positive reputation.
With the 90 degree weather last week I started using my sunroof again. Only issue is the damn thing wouldnt open. After finally using the vent button to break the seal, it would then open. Looking at all of the seals and tracks they where bone dry. The heat was causing the seals to basically glue themselves to the glass. So I looked up the sunroof service in the Ford factory service manual and it called for lubricating the seals and tracks with Krytox. I ordered it from amazon
Krytox Krytox
applied it and now the sunroof is quite, opens smooth as glass.
Old 05-15-2019, 05:06 PM
nuctrooper
nuctrooper is online now
nuctrooper has a good reputation on FTE.nuctrooper has a good reputation on FTE.
I have been using 3M brand Silicone Spray (DRY) and it is working like a champ. Not sure what the Krytox formulation is, but I agree that the right lube has eliminated all of the popping and sticking I used to have and I am no longer hesitant to open the sunroof!
Old 05-15-2019, 05:15 PM
pdose
pdose is offline
pdose is starting off with a positive reputation.
This is a great piece of information. I personally believe this piece of maintenance is overlooked by most owners and many dealers. Many are afraid of using their panoramic sunroofs but I keep the seals and rails lubricated and don’t think twice about opening it if the weather is nice
Old 05-15-2019, 11:41 PM
Adam R
Adam R is offline
Adam R is gaining momentum as a positive member of FTE.Adam R is gaining momentum as a positive member of FTE.
I was planning on using some silicone grease to lube mine when I receive my truck. I’ve used this grease (scuba diver o-ring grease) to lube the window track rubber on 20+ year vehicles with great success. I’d wager that this “sticking” is the main cause of broken sunroof tracks.
Old 05-16-2019, 01:03 AM
GrantGunderson
I would imagine that teflon or silicon will work as well. However there is quite a bit of documentation online on various vehicle forums warning against using silicone on sunroofs and Krytox specifically states that it does not include silicone so I went with the mfg's recomendation. Plus a little goes a very long way.
Old 05-16-2019, 06:09 AM
zeroo's Avatar
zeroo
zeroo is online now
zeroo is starting off with a positive reputation.
Sticking is 100% the reason the roof breaks, or 99.9%.
Old 05-16-2019, 12:34 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
well I am glad there is a specific ford recommendation. I just ordered it.
when I had my 2010 I had a problem with mirrors sticking and rear window sticking...I lubed them with some neutral spray lube...it made the problem worse as the lube acted like glue.
Old 05-16-2019, 01:48 PM
Adam R
Adam R is offline
Thanks for the information. I’ll pick up some of that krytox lube.
Old 05-16-2019, 03:50 PM
nomad_archer
nomad_archer is offline
nomad_archer is starting off with a positive reputation.
Which seals are you applying this too? The seal all around the glass or just the big seal between the two panes of glass? I wish this wasnt $30 for 1.9fl oz but I really dont like the alternative so I will pony up as my sunroof likes to pop even after being vented. It usually takes 2 pushes of the open button for the glass to move rearward.
Old 05-16-2019, 04:44 PM
dnoel
dnoel is offline
dnoel is starting off with a positive reputation.
Worse yet, it's for 1 oz. of fluid. 1.9 is the weight.
Old 05-16-2019, 05:48 PM
nomad_archer
DOH!!! I gotta read a little slower. Stuff must be gold.
Old 05-16-2019, 06:04 PM
ExDakotaOwner's Avatar
ExDakotaOwner
ExDakotaOwner is offline
Pickup Trucker
ExDakotaOwner is a splendid one to beholdExDakotaOwner is a splendid one to beholdExDakotaOwner is a splendid one to beholdExDakotaOwner is a splendid one to beholdExDakotaOwner is a splendid one to beholdExDakotaOwner is a splendid one to beholdExDakotaOwner is a splendid one to behold
Wish I saw this a year ago...Mine is broke and had to pay $100 to get it closed (was stuck open)
Old 05-16-2019, 08:12 PM
Xwild's Avatar
Xwild
Xwild is offline
Xwild is gaining momentum as a positive member of FTE.
did it specifically call for that version of krytox? as there are a number of krytox products..
Old 05-16-2019, 10:54 PM
GrantGunderson
I applied it to all seals and edges. It probably only used 1/10 of what came in the container so a little goes a very long ways. I would recommend wiping the dirt off the seals with a clean microfiber cloth first as well.
Old 05-16-2019, 10:55 PM
GrantGunderson
I posted a link to the correct stuff on amazon. It came with a reusable applicator as well.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
