6.2L V8 Discuss the 6.2L V8
Thinking of changing my own oil.
Old 05-15-2019, 12:21 PM
my_crib_too's Avatar
my_crib_too
my_crib_too is offline
my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.
With my new 2019 6.2L, I'm thinking of changing my own oil at home. Been about a decade since I've done this. It looks so simple on the F250. Everything is out in the open.
Any tips or tricks you can share?
Have some mobile 1, Ford filter, grease gun.
Are people using a bucket to catch the used oil? Just the two grease fittings or are there more? Anything else to share?
Going back to changing my oil because it's a minimum of an hour at the dealership with their Quicklane. Generally more. Seems like I can do it myself faster.
Bruce
Old 05-15-2019, 12:53 PM
cob1181
cob1181 is offline
cob1181 is starting off with a positive reputation.
I've done all my own oil changes since the truck was new. It's one of the easiest vehicles I've done. I use a large oil pan which works great. Two pieces of advice.... 1. don't do it on windy days. There is a lot of room underneath for the wind to blow the draining oil everywhere.
2. Dont use Mobil 1 oil filters on this engine. I used them for 4 oil changes and everytime they leaked. The first three leaked just enough that a single oil drop would be suspended on the bottom of the filter. I cleaned it off with a rag and the next day after driving, there would be another drop of oil on the bottom of the filter. The 4th one leaked enough that it dripped onto my driveway. I immediately switched that one out with a ford filter. 1000 miles later and the ford filter is still clean. I dont know why this happened. The filter dimensions appear to be the same.
Old 05-15-2019, 12:55 PM
cob1181
cob1181 is offline
My F350 only has 2 grease fittings and they are on the front axle u joints
Old 05-15-2019, 02:07 PM
my_crib_too
Thank you for the response, those are the two that I saw.
Bruce
Old 05-15-2019, 02:08 PM
my_crib_too
Lots of good tips, thank you. Ford filter for me.
Bruce
Old 05-16-2019, 05:57 AM
kry226
kry226 is offline
kry226 is starting off with a positive reputation.
I also always do my own maintenance. I just changed mine for the first time and in addition to what's already been said, I found the use of a longer funnel helpful as the oil fill is quite a bit lower than the intake and other appointments on the top side of the engine.
Also, the drain plug started to leak oil as soon as I broke the seal so be prepared for that. Most of my other vehicles, I was able get the plug off without spilling a drop or getting oil all over my hands. Not so in this case.
Have fun!
Old 05-16-2019, 07:02 AM
Chuck's First Ford
Chuck's First Ford is online now
Chuck's First Ford has a great reputation on FTE.Chuck's First Ford has a great reputation on FTE.Chuck's First Ford has a great reputation on FTE.Chuck's First Ford has a great reputation on FTE.
maintenance... its called work.. you will get your hands dirt...
pay me now, or pay me later.. I heard that someplace..
gone are the days of
canister type oil filters
oil bath air filters.
but then there was a day.. engines did NOT have oil filters..
or the day. engines did not have oil pans... "total loss oiling system"...
you adjusted the oil flow from the tank to bearings to the ground.. from the dashboard...
dam, < History >
Old 05-16-2019, 09:27 AM
Jack4x's Avatar
Jack4x
Jack4x is online now
Jack4x is starting off with a positive reputation.
Buy a Fumoto valve and you'll wonder why you ever messed with a drain plug.
Old 05-16-2019, 10:32 AM
my_crib_too
Which valve fits this truck?
Bruce
Old 05-16-2019, 11:22 AM
rvpuller's Avatar
rvpuller
rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
Bruce
I don't know where you go for you oil changes but most of the ones I use all over the country at Quick Lanes are $50 - $55 out the door. Maybe after I'm off extended warranty I may change it myself if it's close to time and I'm home.
Denny
Old 05-16-2019, 12:32 PM
my_crib_too
Denny
Denny,
Good information on cost. My main issue is around speed though. I'm sure that it's limited to just my local dealership but getting cars through is painful. Never seen workers move so slowly. They do good work but even with no others in line, it's an hour. On a Saturday morning with a few vehicles in line, its hours. Drop the truck off and pick it up later in the day. Should take the word quick off the building.
Bruce
Old 05-16-2019, 02:17 PM
Chuck's First Ford
oh, "Time"...since 1966...
20 minutes for this OLD man... walks with a cane... I do my own...
with my trusty Dog Bone creeper...since 1989.
do not forget to lube the door hinges... check all the lights..
I also still ride my motorcycle..
Old 05-16-2019, 02:59 PM
rvpuller's Avatar
rvpuller
Denny,
Bruce
I've learned to call ahead and make a appointment, it wasn't that wa a few years ago but it seems to be normal now plus I'm from out of town so not at the top of the list except for the dealership in Kerrville TX because we stop there every year and have it done when we are at a rally.
Denny
Old 05-16-2019, 07:06 PM
tibadoe's Avatar
tibadoe
tibadoe is online now
tibadoe is starting off with a positive reputation.
Any tips or tricks you can share?.......................
I have to agree that my F350 is about the easiest oil to change out............mostly after I installed a Fumoto valve. I did a oil change write up if you want to check it out: F350 6.2L Oil & Filter Change
Old 05-17-2019, 05:50 AM
my_crib_too
Wow, comprehensive write up. Thanks, enjoyed reading!
Bruce
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
