2015+ F150 Discuss the 2015 Ford F150
2016 with 5.0 squeal on start up??
Old 05-14-2019, 09:04 PM
Z06 FAN
Z06 FAN is offline
Z06 FAN is starting off with a positive reputation.
When I start my 2016 f150 with 5.0 it is squealing briefly and I'm not sure what it is. Its random and don't seem to do it every time and its loud. Anyone else experience this or know what the problem could be? Truck has 44,000 miles on it so i'm not sure if it simply needs a new serpentine belt?
Old 05-14-2019, 09:13 PM
msgtord's Avatar
msgtord
msgtord is offline
msgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to all
Probably the belt. At 44,000 miles I'd go with a new belt. But, you can try spraying some belt dressing and see if that stops it. It will be a temporary fix, but it should stop the squeak.
Old 05-15-2019, 02:51 PM
GABAR's Avatar
GABAR
GABAR is offline
GABAR has a good reputation on FTE.GABAR has a good reputation on FTE.GABAR has a good reputation on FTE.
Sounds like the serpentine belt is slipping.
Buy a new one, install it, and see if the squeal goes away.
Old 05-15-2019, 03:43 PM
dlburch
dlburch is offline
dlburch has a good reputation on FTE.dlburch has a good reputation on FTE.
there was an issue on some older models when it was "cold" outside, one of the idler pulleys would squeal for several seconds after initial start...
Old 05-18-2019, 06:14 AM
Z06 FAN
Z06 FAN is offline
Guess I will change out the belt and see what happens. Cheapest and easy!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
