312 Oil filter adapter plate
Old 05-12-2019, 02:29 PM
Hoppy57
Hoppy57 is offline
Hoppy57 is starting off with a positive reputation.
Last oil change oil filter adapter plate loosened when spin on oil filter was removed. Tightend back up but should something like lock tight be put on the bolt that connects to block to help hold it from loosening during filter change?
Old 05-12-2019, 07:01 PM
f5fordgirl
f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
The instructions with the adaptor I bought suggested that lock tight be used, and how tight are you turning the filter?
Old 05-12-2019, 08:50 PM
charliemccraney
charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
The torque spec for that "bolt" is 20-25 ftlbs according to my '61 shop manual. That is far more than should be required to loosen the filter and it should not come loose when torqued correctly.
I don't recall the size of the nut but what you want to do with the socket you use is to use a belt sander to grind the inside chamfer off so that the socket engages more of the thin hex of the bolt, to avoid slipping off and rounding it.
Old 05-13-2019, 06:43 AM
Hoppy57
Hoppy57 is offline
Next go around I will check the torque on that bolt. Thanks
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
