460 starting problem linked to shifting linkage????
Recently I ran into a problem of my truck not starting from park. My shifter is a bit sloppy on the column and have noticed that I have to push it firmly into park. The truck wont start from the ignition, but will start if I put the key in the start position and then spark the solenoid with a screw driver. I have read that it might be related to the Safety Neutral Switch which is located on the tranny (I believe). Any suggestions or troubleshooting anyone knows about that I can do? Truck runs amazing once it is started.
I have a 1996 F250. I haven’t yet looked at the column. But I will check that soon. I replaced the safety neutral switch and seen that there was some adjustment on the linkage that I am going to adjust. I can tell that the position of the safety neutral switch is very important and that has a lot to do with it.
iron1951
02-18-2011 06:39 PM
bob_c_us
1999 to 2016 Super Duty
03-02-2009 02:58 PM
Pwarrenn
09-26-2007 06:01 PM
sparky
12-05-1999 05:38 PM
