Question for the roller pros
Old Oct 3, 2003 | 07:37 AM
jmackie's Avatar
jmackie
Hi all, I would like to know what position does the roller tip have to be on the valvetip when valve is closed. centre, or closer to either side of the valve tip?? Does the roller tip push the valve strait down, or start from one side and move to the other. thanks.
Old Oct 3, 2003 | 10:02 PM
proeliator's Avatar
proeliator
If memory serves it sits more on the outer side of the valve stem...at least with the Harland Sharps.
Old Oct 4, 2003 | 07:38 AM
greenhighboy's Avatar
greenhighboy
With the valve closed it should be toward the inside then as the valve opens it should roll across the stem to the outside when the valve is open. The roller should be on the center of the stem at half lift. Comp Cams has a picture of this on their website. This is how they say to find the correct pushrod length.
Dennis
1999 F-350 Powerstroke
1977 Highboy 429 4-speed 35"s
1972 Ranger on a 1978 F-250 4x4
frame 466 Pulling Truck
Old Oct 4, 2003 | 12:54 PM
qtrmiler's Avatar
qtrmiler
Center of the cams lift should be center of the valve tip
Old Oct 5, 2003 | 11:46 AM
greenhighboy
What is center lift?
Dennis
Old Oct 5, 2003 | 05:33 PM
qtrmiler's Avatar
qtrmiler
If a cams lift is .600 at the valve, center will be .300. Basically it's half the gross valve lift.
pagokid59
13
Mar 23, 2010 11:33 PM
C-Leigh Racing
28
Jan 10, 2009 10:07 AM
coop_22
Apr 21, 2008 09:35 PM
BigJake86
Mar 15, 2003 08:26 AM
FEina52F1
Feb 11, 2002 10:06 AM
