A little help from the other side of the world
Old 05-09-2019, 09:11 PM
Justwanderinthrough
Justwanderinthrough is offline
Justwanderinthrough is starting off with a positive reputation.
Ok little background Ill make it quick ish. My wife and I are currently overlanding through South America, at the moment were in Cusco , Peru. Were driving my early 1999 F-250 CCSB, 7.3, 4x4 with automatic transmission. Been great so far. Problem at hand is as follows.... I upgraded the transmission cooler before we left for the trip to the 6.0 cooler that has 1/2 lines. Now when coming down one of the many and crazy mountain passes I went to hit the gas on te next incline and had no gears. Nothing forward or reverse. Turns out where the factory 3/8 transmission line connects to the barbed fittings that takes it to 1/2 came apart and dumped about half my fluid right there on the road. (I followed a small drop trail of fluid back up the road and found nothing major) So seems as if when I came coasting down the hill and mushed on the gas to get up the next hill the pressure caused the fittings to blow off.
Anyway, panic panic panic. Found he leak, hooked everything back together tossed in the 4 qts of extra fluid i had and I was able to get the truck off to the side of the road without being killed by crazy colectivo driver or run away semi.
I hitchhiked to the next town and bought what transmission fluid I could find which was Dexron III ( hope theyre compatible ish because I use Mercon V) topped it off and two hours driving later all seems while from the outside. Tomorrow I plan on pulling the pan off and see what I can.
My question is can any of you fine folks help me out of what parts are needed for a transmission rebuild if this does indeed become my reality? Ill be putting some legwork into this in the next couple days but thought Id start here. Any good kits? Im not looking for crazy upgrades just basic rebuild. My truck is stock except for intake and small lift to fit 35s. And Id like to keep it that way. Plus Ill have to have these parts shipped to Peru so thats another bit of fun to figure out.
Old 05-15-2019, 03:09 AM
Fifty150's Avatar
Fifty150
Fifty150 is offline
Fifty150 has a good reputation on FTE.Fifty150 has a good reputation on FTE.Fifty150 has a good reputation on FTE.
Originally Posted by Justwanderinthrough View Post
where the factory 3/8 transmission line connects to the barbed fittings that takes it to 1/2 came apart and dumped about half my fluid right there on the road. .
Did you use a hose clamp?
bought what transmission fluid I could find which was Dexron III ( hope theyre compatible ish because I use Mercon V) .
Which transmission is in your truck? There's a door jamb sticker with a transmission code.
You should know which transmission you have, so that you can be sure that you are using the correct ATF. Which fluid was specified for that transmission? No point worrying about it now, since you are planning a rebuild. You will have to drain all the fluid anyway. You will fill your rebuilt transmission with fresh fluid.
What did you see when you dropped the pan?
Rebuild kits are all over the internet for Ford transmissions. But you will need to know which transmission you have, before you can shop, price, and compare kits. There are a few members who have professional insight. One active member is in the transmission business.
While you have the pan dropped, you may as well drain the torque converter. If you rebuild, you should fill with fresh fluid. If you don't refill, fill with fresh fluid so that you now have a baseline with fresh fluid. You won't have to wonder about the Dex III you added. Most people would suggest that you fill with Mercon V, since Mercon V is now the suggested fill for all of the older transmissions which called for Mercon. Unless you prefer a multi-vehicle ATF formulation like Mobil, Royal Purple, Amsoil, Valvoline, Lucas Oil, et cetera.
Old 05-15-2019, 03:11 AM
Fifty150's Avatar
Fifty150
Fifty150 is offline
I think that most vendors will ship to Peru, as long as you are willing to pay for the shipping.
I'm interested in what you will have to pay for shipping.
Old 05-15-2019, 08:43 AM
Justwanderinthrough
Yes sadly used hose clamps. Ive double them up since this happen and have been searching for a proper crimp.... things are a little harder to come down here and Ill have to wait until we get to larger city.
Im not sure how to read the door jam sticker to find out what transmission I have. Same sticker with vin and tire info correct. Guess Ill google some more.
When i dropped the pan it was actually surprisingly clean. No chucks and very little fuzz on the magnet. Which I was pretty happy to see.
I filled it it back up with the only Mercon v I could find between here and Lima. They only have 10 qts so could do a flush. But she driving and shifting as normal. Once we get to the next big city Ill continue with a search for MerconV and hopefully get it all flushed.
Side not not I was under the impression the TC and tranny are connected.... same fluid right. I realize just driving the pan doesnt drain the TC but the new fluid I put in will mix into the TC correct?
Old 05-15-2019, 08:45 AM
Justwanderinthrough
I have no doubt it could get shipped the hard part Ian once its in Peru. Getting it to clear customs in a timely manner and then actually having it delivered to wherever.
Old 05-15-2019, 08:53 AM
Justwanderinthrough
Ok transmission code is E so guess I have the e4od. Which calls for MerconV. Everything Ive read says dexIII should be ok....
Old 05-15-2019, 08:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
You have a 4R100 transmission. 1997 was the last year for the E4OD. The 4R100 uses MERCON V.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
