2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Low profile sharkfin antenna?
Old 05-08-2019, 08:11 PM
Yankee301
Yankee301 is offline
Yankee301 is starting off with a positive reputation.
Just brought home the new Super Duty today. My garage door hangs below the frame. The sharkfin antenna would hit. I plan on raising the door. Is there an aftermarket low profile sharkfin antenna replacement out there so I could get a bit more clearance?
Old 05-08-2019, 08:17 PM
h20camper's Avatar
h20camper
h20camper is offline
h20camper is gaining momentum as a positive member of FTE.h20camper is gaining momentum as a positive member of FTE.
Not sure about your question but wanted to say Nice Looking Truck! Welcome to the forum too.
Old 05-08-2019, 08:18 PM
RCR70ss
RCR70ss is offline
RCR70ss is starting off with a positive reputation.
They do use a lower profile one on the New 2020 Fords!
Old 05-08-2019, 08:37 PM
Mud Doc's Avatar
Mud Doc
Mud Doc is offline
Mud Doc is starting off with a positive reputation.
What do you need, an inch? Might check with a door opener company--probably can get you that little more space.
Old 05-08-2019, 08:44 PM
Yankee301
Thanks. Ordered April 1st and arrived May 6th which I thought was super fast. I have the door company coming out so hopefully they can set the door limit higher. Still would be nice to get a bit more clearance with the sharkfin. I just saw the 2020 comment. Maybe that will trickle down then. I bought the truck to handle our travel trailer better and didn't want to lose a season waiting on the 2020s.
Old 05-08-2019, 08:55 PM
h20camper's Avatar
h20camper
I thought the 2020s were mounted on the rear of the cab (and look funny). Maybe just takes time to get used to looking at.
Old 05-08-2019, 09:00 PM
Manos's Avatar
Manos
Manos is offline
Manos is starting off with a positive reputation.
Not sure if the older ones are the same function my 2017 has flat oval shaped antenna that is lower than the lights on the roof. It isnít painted to match either.
Old 05-08-2019, 09:09 PM
h20camper's Avatar
h20camper
I think the shark fin one adds cellular (FordPass) support. My 2019 only has Sirius and has the oval roof antenna like yours.
Old 05-08-2019, 09:23 PM
Yankee301
That is probably right. I do have FordPass Connect.
File Type: pdf
Old 05-08-2019, 09:24 PM
Manos's Avatar
Manos
Manos is offline
Ah ok that makes sense and means the older ones are no help for the OP
Old 05-08-2019, 09:26 PM
Section179
Section179 is offline
Section179 is starting off with a positive reputation.
Hammer time
Old 05-08-2019, 11:49 PM
zekes66
zekes66 is offline
zekes66 is starting off with a positive reputation.
Those almost look like flashers or something. Maybe for WIFI hotspots?
Old 05-09-2019, 06:51 AM
h20camper's Avatar
h20camper
I think the WiFi hotspot is under the dash. You'd want it inside the cab for better connectivity.
Old 05-10-2019, 07:46 AM
jackbauersmom
jackbauersmom is offline
jackbauersmom is starting off with a positive reputation.
I have the same "shark fin" antenna. just be careful when you try and drive through as the highest point of the truck is actually the rear of the cab. be sure to have someone watching you the first time if you are that close.
Old 05-10-2019, 10:12 AM
6.2caribou
6.2caribou is offline
6.2caribou is starting off with a positive reputation.
^^^^^This!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
