Air Intake Hoses from Air Cooler to Throttle Body
Old 05-07-2019, 05:36 PM
JesseRayV's Avatar
JesseRayV
JesseRayV is offline
JesseRayV is starting off with a positive reputation.
I have had the hardest time trying to fine the dual hoses that come off of my air intake all the way up to my throttle body. I have searched an searched through Ford and the part is now obsolete. On the aftermarket sites they seem to only carry the air intake but not the hoses. I have found it on EBay for a ridiculous amount that I am not going to pay. Does any one have any suggestions as where to get replacement hoses or will I have to just find something that will work?
Old 05-07-2019, 07:14 PM
EllieMae94's Avatar
EllieMae94
EllieMae94 is offline
EllieMae94 is starting off with a positive reputation.
You should be able to find plenty in the junk yards for cheap. You are referring about the hoses for an SD setup, correct? What truck is this for?
Old 05-07-2019, 08:36 PM
JesseRayV's Avatar
JesseRayV
It’s a 96 F250 Heavy Duty with 7.5L 460 in it. And yes, its the hoses that come off the air intake that lead up to the throttle body. I don’t want to go with a used one so what I ended up doing was doing a memory flex hose that adapts from the 3 inch side of intake to the 2 1/2 inch side to the horn. I was actually pretty pleased with it and will see how I feel about it. So far, I feel like the air flow is much better but it hasn’t even been a few hours so we will see over the next few days.
Old 05-08-2019, 04:09 PM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I fail to see what is wrong with using a used air intake tube. That would be my preferred option if a new one was not available or expensive. There is nothing wrong with using junk yard parts like this. I'd much rather have the correct tube than something funky.
Old 05-08-2019, 05:10 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
My4Fordtrucks is gaining momentum as a positive member of FTE.My4Fordtrucks is gaining momentum as a positive member of FTE.
Iím with him. There is or should be only clean filter air flowing through it from the air box. Whatís wrong with using one from the junkyard? Especially if you were initially interested in getting the part from Ford.
Old 05-08-2019, 07:20 PM
JesseRayV's Avatar
JesseRayV
I could understand your suggestion for sure, but I was just looking for other options that were available. I wanted to get it from Ford just because I felt like it was a common part to have available. After finding that it was obsolete and that junk yards was my main option, I wanted something more readily available if I were have to replace it again. I ended up putting a rigid memory flex hose on it and I am rather pleased with it. What do yo guys think of a memory flex air intake hose? I am open to opinions and suggestions. Please be honest, I as I have yes and no opinions on them as well.
Old 05-08-2019, 07:30 PM
My4Fordtrucks
I’m lost. Why would you need to replace it again? Why did you need to replace it in the first place? In 23 years I have never had an air inlet tube wear out.
Old 05-08-2019, 08:55 PM
95fiveoh's Avatar
95fiveoh
95fiveoh is offline
95fiveoh is gaining momentum as a positive member of FTE.
Originally Posted by My4Fordtrucks View Post
Iím lost. Why would you need to replace it again? Why did you need to replace it in the first place? In 23 years I have never had an air inlet tube wear out.
I've seen them split from age, but not often, and I too am confused why you wouldn't just grab a junkyard one. Probably would cost you all of $5 if you pulled it yourself.
Old 05-08-2019, 09:41 PM
JesseRayV's Avatar
JesseRayV
I had a pin hole leak in a hose at the driver side top of my radiator where my radiator cap is. It was very tiny and what was happening was that the air intake was sucking in that antifreeze that was dripping from that pin hole and going straight into those hoses. They caused my hoses to swell very bad. I didn’t notice it right away as it wasn’t an immediate change in the hose size. They got so bad that they got soft and started rubbing on my hood. I have fixed the radiator leak and just did a bunch of maintenance to the truck this past week and did not run into any internal problems from that antifreeze being sucked in to the air intake. I know that this is a one off case from the hoses swelling because I have buddies as well that have never had to replace there’s; but they also have never been in the situation that I was in.
Old 05-09-2019, 05:28 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by JesseRayV View Post
Itís a 96 F250 Heavy Duty with 7.5L 460 in it. And yes, it's the hoses that come off the air intake that lead up to the throttle body. I donít want to go with a used one so what I ended up doing was doing a memory flex hose that adapts from the 3 inch side of intake to the 2 1/2 inch side to the horn. I was actually pretty pleased with it and will see how I feel about it. So far, I feel like the air flow is much better but it hasnít even been a few hours so we will see over the next few days.
F5TZ-9B659-G .. Outlet Duct / Obsolete
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
Old 05-09-2019, 10:27 AM
CamoF-250's Avatar
CamoF-250
CamoF-250 is offline
CamoF-250 is starting off with a positive reputation.
I have wondered before if an exhaust shop could bend up a nice intake hose, just install it with rubber couplings on each end to let it flex.
Old 05-09-2019, 10:43 AM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
KubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to all
Have any pictures of the new setup ?
Old 05-09-2019, 08:45 PM
JesseRayV's Avatar
JesseRayV
Here is a picture of the new setup. I paid $20 for the flex hose and then $10 for the adaptor from Oreillys. I am waiting on the other set up from Amazon since they are a bit cheaper. I plan on going all the way up to the throttle body with these flex hoses. I like them, what do you guys think? Ill post a picture of the complete setup when I finish it.
Memory Flex Air Intake Hose from Spectre. 3 inch off the Air intake side toe to a 2 1/2 inch on the horn side.
Old 05-09-2019, 09:36 PM
My4Fordtrucks
It looks like dryer vent hose. Is it corrugated on the inside too? I wonder how that affects airflow?
Old 05-09-2019, 10:13 PM
eagle275's Avatar
eagle275
eagle275 is online now
eagle275 is starting off with a positive reputation.
I'm wondering about that too.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
