1993 Ford E250. Power distribution box seems to be blocked by brake lines and an AC line. Is there a trick to accessing the relays? I can't figure out how to remove the lid - mystery tabs everywhere. Thanks for help.
Pop the tabs, and finagle it out to the rear. It's a pain, but there's no magic to it. Just a poor design.
Thank you - it wasn't too bad. Had to activate levers in front and back then move around carefully under brake lines. Blocked in directions I wanted to go but with a little imaginative geometry got to what I needed.
