Fe rear sump oil pan dipstick
I recently bought a 390 to put in my 75 f-250 4x4 after the 360 took a crap. The 360 that was in the truck had a front sump oil pan and the dipstick in the block by the timing cover that attaches to cyl 5 exhaust bolt. The dipstick is marked D5TE-6750-DA. The “new” 390 has the correct rear sump 4x4 pan that uses a dipstick in the pan. The 390 had the dipstick hole in the pan plugged and had a dipstick in the front. This dipstick tube attaches to the coil bracket hole on the front of the head and the dipstick is marked D0AE-6750-A. The problem is that I don’t think it is reading right with 7qts of oil in it this dipstick reads over 2qts low. The dipstick and tube out of the other engine reads at the top of the safe zone if I use them. My question is can either of these dipsticks be used with the rear sump pan and if so which is correct? Id rather just leave the pan plugged and use one of these if I can. If neither of these can be used what is the correct dipstick that goes in the pan?
The dipstick tubes appear to be the same length but fasten to the engine different
The difference in length of The dipsticks when lined up. The D5TE on top and the D0AE below it
D5TZ-6750-B .. Engine Oil Dipstick / Marked: D5TE-6750-DA = 1975 F100/250 2WD & F350 360/390 from serial number W00,001 / 1976 F100/250 2WD & F350 360/390.
D0AZ-6750-A .. Engine Oil Dipstick / Marked: D0AE-6750-A = 1970/72 Ford/Mercury Passenger Car 351C & 351CJ.
Wow that was quick thanks! What is the part number for the correct dipstick and tube for the rear sump pan? Also can the c5 dipstick work with the rear sump if I plug the hole in the pan and use the hole by the oil filter?
Oops my my bad I meant D5. The D5TE-6750-DA front sump dipstick. If used in the block hole will it read accurate with the rear sump oil pan?
Hmm okay this link confused me then http://www.fordification.com/tech/dipstick.htm
Do do you happen to know what the differences between before W00,001 and afterand the part numbers? I have no clue what this pan originally came from, is there a way to tell if it was from before or after the serial number break?
I understand the concept and have done this with the front sump stick but I would like measurements of the correct stick that mounts in the pan (mostly looking for dipstick tube length) so I can make a dipstick to go in the pan
onetonscs
08-07-2011 04:14 PM
woodsrider505
05-02-2005 02:49 AM
