96 f250 leaning to passenger side!!
My truck is a 96 f250 but has been converted to a solid axle. When I bought the truck it had a 4 inch lift in it, and it seemed to sag towards the passenger side about one inch. Last weeken I took the front lift springs out and installed a pmf rsk with v code super duty springs. Now I have a 2 inch lean to passenger side, its very noticeable and bothers the hell out of me. How can I fix this l? Are there front leaf spring shims out there ? Could it be body mounts ?
Measure from the bottom of the cab to the top of the frame on each side to sorta check out if cab mounts are contributing. Then from frame to ground on as level of a surface as possible. I unfortunately work on a gravel surface which slopes from one side of the truck to the other. It makes lifting the truck of on 4 stands safely and efficiently sort of tricky.
I took measurement from the cab to frame. The passenger side of the truck is defianlty closer to the frame than the driver side. But not two inches. I have new cab mounts waiting to go in. If that doesnt straighten the body out, should I shim up the body to get level? And other options? Thanks for feed back
ranchrods
04-04-2016 12:35 AM
