Truck died again
Truck died again
I posted a new thread back in Feb about truck died while idling after test driving with new #2 injector install. After all that, I reinstalled the IPR valve and it started and ran fine. Mind you the screen was still intact. I drove it for about 3 weeks and had no trouble. Ran perfect. I moved my son to his new house and made 3 good loads down to his house. I got up the next morning to go down an drill out 2 more dead bolts. The truck had a miss just like it did before I replaced the injector. Just before getting home we stopped to get something to eat. When I came out to leave I started it up and pulled out of my parking spot. Had no throttle and it went dead. Called a wrecker. Now I just replaced the IPR, stand pipes and dummy plugs. This is what I got on my Scangauge ll.
RPM = 193
ICP = 234
IPR = 84.7
FICM = 48.5v
FICM sync = 1
I am at a total loss.
2005 F250 6.0
RPM = 193
ICP = 234
IPR = 84.7
FICM = 48.5v
FICM sync = 1
2005 F250 6.0
I know this is old but I’ve been a on mandatory 12 hr shifts and can’t get time to work on this. So I bought the IPR air test adapter and hooked up shop air and right away had a leak. The o-rings on the dummy plugs and stand pipes on the left side were both blown. Can’t figure that out. Put new ones in and now no air leak at all. Still only building + or - 230 psi. I’m thinking HPOP but they say they rarely go out on ‘05 and up. Mine is an ‘05. What do you guys think?
