Can I put 85 140 gear oil in a bottle jack?
Hydraulic jacks use hydraulic fluid. It is available over the counter as "jack oil".
Your jack is leaking because it has a bad seal. Luckily, almost all hydraulic jacks are the same. Even if your brand isn't common, it will require new seals, o-rings, and gaskets. Those parts are all sold by diameter size. Remove the fill plug and drain it. Take it apart. Get a rebuild kit. Rebuild with new seals, o-rings, and gaskets. A hydraulic shop can do this for you. Look for the places which repair fork lifts, pallet jacks, et cetera. At the heart of most hydraulic equipment, is a simple hydraulic bottle and piston, just like a bottle jack. Those shops should either have in stock, or access from a distributor, seals in every size diameter needed for your jack.
It will be cheaper and easier to buy a new jack.
That does look like a lot of work I have to bottle jacks that don't work in a floor jack that I bought last year doesn't work anymore. I have a Michelin floor jack that still good but the thing weighs a ton and I want something to keep in my truck guess I'll just throw them out and buy a new one thanks for the heads up
I agree it sucks throwing away perfectly good tools but finding all the o rings and seals I would need would take forever. It's not like I can just walk into Home Depot and buy them for like $0.17 a piece last time I needed an O-ring for my Powerstroke it was like 12 bucks the parts counter
I don't know what is available in your area. Where I live, there are shops which repair pallet jacks, fork lifts, just about anything hydraulic. They have those seals in every size.
I have seen sales online. Try contacting:
For REPAIRS and SEALS & PARTS in the Los Angeles/South Bay area try -
B.R.U.S. Enterprises - Daniel Ledur
Ph # 213-712-3830
brusenterprises11@yahoo.com
For SEALS & PARTS in the Long Beach/Orange County area try -
LAZZAR'S Floor Jack & Cylinder - Marc Lazzar
Ph # 562-596-5477
support@hcrcnow.com
For SEALS & PARTS in the Midwest and Eastern USA try -
BLACKHAWKPARTS.COM
910-C Creekside Road
Chattanooga TN 37406 USA
Phone # (423)622-8282
Fax # (423)629-0125
Ph # 213-712-3830
Ph # 562-596-5477
support@hcrcnow.com
BLACKHAWKPARTS.COM
Fax # (423)629-0125
No. But if you take the bottle jack apart, you can remove all the o-rings, gaskets, and seals. Then measure them, and order the correct size for rebuild.
As I recall, most of the bottle jacks on the market have the same specs for size. So if you have a 10 ton jack, you can buy seal kits for a 10 ton jack from just about any manufacturer, and they should be the same diameter. But measure first. Some jacks, like Craftsman, Ford, et cetera, have a couple of spare gaskets thrown into the box when you buy a new jack.
Torin Big Red Jacks has seal kits if you call them. Sears Craftsman jacks are rebuildable, and Craftsman parts should have bottle jack seals.
Harbor Freight sells a o-ring assortment kit. It may have the o-rings you need to rebuild your jack.
https://www.harborfreight.com/205-pi...kit-67644.html
https://www.harborfreight.com/catalo...f&q=o-ring+set
Greywolf
13
04-05-2013 02:27 PM
