'88 Ranger 2.9 4x4 turns over but wont start - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Reload this Page >
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-11-2003, 05:19 PM
Ken00's Avatar
Ken00
Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Glad to hear its running again, what did you replace.
Old 10-11-2003, 07:16 PM
Beast12's Avatar
Beast12
Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
I am glad you got the vehicle running! Yes, this website is a very valuable site which I come to at least once if not 2-3 times DAILY! I would also like to know what the problem was as well.
-Matt
Old 10-11-2003, 07:29 PM
br0ken d0wn
br0ken d0wn is offline
br0ken d0wn is starting off with a positive reputation.
I was following the wires from the I switch. When I got to the relay I thought that the relay was bad, since there was only power to half of the wires. I followed the other wire from the I switch to the fire wall on the drivers side. I was slightly pulling on it and it tore in half. It apeared to be burnt [by the exhaust manifold I assume] so i tied them together and tried to fire it up. It worked out just fine. So I didnt have to replace anything. I have one last question, should I add a inline fuse and if so what size should I use ?
Old 10-11-2003, 07:54 PM
Ken00's Avatar
Ken00
Ken00 is offline
The fuel pump circuit is protected by the fusable link.
Old 10-12-2003, 10:25 AM
br0ken d0wn
i just wanted to make sure , to be on the safeside thank you for all your help ken
Old 11-29-2018, 08:11 PM
tristan nixon
tristan nixon is offline
tristan nixon is starting off with a positive reputation.
where is this link located? im having the same problem i have fuel and spark but wont start
blackcrow_75
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
08-11-2007 04:15 PM
88stxRanger
Ranger & B-Series
03-09-2007 12:14 AM
ztuck
04-04-2006 12:07 PM
The Phenom
Ranger & B-Series
02-26-2005 01:22 PM
icbomber
08-05-2003 09:35 AM
Quick Reply: '88 Ranger 2.9 4x4 turns over but wont start
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
