351c best carburetor??
Old 04-30-2019, 07:31 PM
BSmart2
BSmart2 is offline
BSmart2 is starting off with a positive reputation.
I知 looking into replacing a four barrel Edelbrock carburetor with a new one? What would be the best option for cfm? I would like to keep it an Edelbrock four barrel
I知 not quite ready for fuel injectors at this time.
Old 04-30-2019, 08:07 PM
85e150
85e150 is offline
85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation
I see you posted this in the '61-'66 F100 forum and were directed here to the engine forums. You hit the FE forum, right next to this one which covers the 351C. I fixed it for you, no charge.
So, can we assume you have this 351c (and it is a 351C from a car or Ranchero prior to 1974, right?) in a '61-'66 pickup?
How heavy, what gears, what transmission, what usage? If automatic, what stall speed?
What size is your current carb, and what is the issue with it?
What other engine mods--cam, intake, headers, compression, chrome valve covers--do you have?
Old 05-01-2019, 04:37 AM
Crop Duster's Avatar
Crop Duster
Crop Duster is offline
Crop Duster is gaining momentum as a positive member of FTE.
Yes, all those questions need answered.
You say you want to stay with Edelbrock so you should call their tech line and talk to them. My guess is they will say a 650 or 750 AVS2.
I just swapped out my stock cast iron square bore 4V intake and 670 Holley for a Blue Thunder and a 780 Quick Fuel. The heartburn from the cost of those parts is still with me, but it woke that thing up, remarkable difference.
Old 05-01-2019, 03:09 PM
BSmart2
BSmart2 is offline
Carb question
Ok I値l need to dig into that.
it is a 1962 F100 Flareside rearmed looks stock. The 351C came out of a car. Not sure of the year. I知 not much of a gear head but will be with all your help. I do appreciate all the feedback! I知 not sure of the current cfm of the carburetor. It is an automatic.
Old 05-01-2019, 04:58 PM
85e150
85e150 is offline
Your 4th picture shows some numbers stamped into the base of the carb to the left side as you face the carb. Those might tell the specifics of the carb.
Looks like this has been running for a while. Is your pcv just laying there as shown or is that hooked up somewhere?
How does it run?
Old 05-02-2019, 04:59 AM
Crop Duster
More than Carb!
Ditto on those numbers.
From what I see in those pictures that carb is probably not all of your problems. Your vacuum advance isn't connected which will make it impossible to get a decent idle. You say you have an automatic but there is no kickdown rod connected to the carb.
The pictures aren't clear enough to tell for sure if it is a 2V or 4V engine. First thing to do is look at the top corner of the heads and see if there is a number 2 or 4 on them that has a lot to do with what kind of tune it will tolerate. You can see the 4 cast in the head in the picture.
You need to get on e-bay and buy a Ford shop manual for a 1971 Car, Volume Two engine. That way you will have all the info you need to wrench on that thing. I say 71 because that year manual has most of the info in one place instead of scattered around two or three different books.
Keep in mind that most carb problems are ignition related. And from what I see in your picture you likely have ignition problems. That distributor appears to have been converted to some sort of electronic, possibly a Pertronix.
Now for the $24,000 question dose it run and drive now?
Old 05-02-2019, 10:12 AM
baddad457
baddad457 is offline
baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.
Can't tell from the pics, but are you sure it's a Cleveland and not a 351M ? Big difference between the two. Clevelands were never installed in trucks by Ford, so of course if it were a Cleveland, it came from a car. They were only around here for 5 years, and there's a huge difference between a 70 4 bbl Cleveland and a 2 bbl 74 motor in terms of tuning and output. But on closer look, that's a 2 bbl Cleveland, the block isn't tall enough to be an M and the intake port castings aren't large enough to be 4 bbl heads. Any carb in the 600-750 cfm range will work.
Old 05-03-2019, 09:06 AM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
Aaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to behold
Has to be a Cleveland, the 351M and 400's both had that extra piece of "ribbing"/"strength"/"gusset" just outside the distributor hole, nearest the driver side head. If you look closely at his pics, he doesn't have that piece which indicates to me it's a Cleveland. I could be wrong though.
Old 06-16-2019, 12:17 AM
BSmart2
BSmart2 is offline
Ok I知 making progress
I figured red out why the previous owner didn稚 connect the vacuum hose for vacuum advance. He had it turned in all the way and it was running 30 over. I back it almost all the way out. To finely get it to idle at about 8 over and no it has a little peep! Now when I rev it to 2500rpm I see the advance advancing. 30 ish over. I知 going to switch over the plugs and wires next. Thank all for all your words of wisdom!!! I値l keep posting my progress
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
