6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4l EGR Delete
Old 04-27-2019, 04:12 PM
Russ0964's Avatar
Russ0964
Russ0964 is offline
Russ0964 is starting off with a positive reputation.
6.4l EGR Delete
Started my EGR delete and I have only one problem, the vertical cooler block off plug didn't go in so well. the housing that the plug sits in cracked, actually a chunk of it broke right off. so my question is has anyone else had this problem and how did you resolve it? also will that plug fit on the thermostat housing where the elbow goes? Other than that the coolers came right out and everything else went smooth. This picture is not mine, just using it as a reference for the parts in question, the part circled is the elbow I am referring to.
Old 04-27-2019, 07:29 PM
Russ0964's Avatar
Russ0964
Russ0964 is offline
Update, I called a local diesel shop and the said I would need a new front cover, quoted me like $1500-$2000. Well after looking around online and on my truck I decided to pop that elbow off. Now I broke it in the process but that's ok it was broke anyway. The elbow is the same size as the plug, so in its place I put the plug in. I just did some driving around and it works just fine, it was a little harder to get in as there is less room for your hands, but all in all, it saved time and money. for those out there doing EGR deletes be aware that the elbow is weak and brittle, It did not take much force to break that thing, but this is a possible solution.
Old 04-28-2019, 11:38 AM
73fan's Avatar
73fan
73fan is offline
73fan has a good reputation on FTE.73fan has a good reputation on FTE.
Good point you make there, man. I have different times if I had a 6.4L engine out and was removing the coolers, also removed the little elbow. Itís one of those things that doesnít really make a difference, but itís a little detail. It hides the plug better. And in your case itís a huge benefit.
Old 04-28-2019, 06:30 PM
DieselDenny
DieselDenny is offline
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Thanx for that! Going to delete next weekend.
Denny!!! Long over-due
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
