B code vs F code Superduty rears
Old Apr 27, 2019 | 02:26 PM
pirate4x4_camo's Avatar
pirate4x4_camo
And just to clear the air,
I have no problem with ATS and acknowledge they have good customer service and that back in the day the X/B or C spring was a decent way to go..
but with better option available now why dont you or the suspension Engineer tell us why you think a dual rate spring with a1000 pound spring rate is the BEST option for the Excursion.
But since I already know you can’t why don’t you guys built a spring exclusively for the Excursion that has a better spring rate and more up travel ?
Getting by selling the F250 spring is not doing us Excursion owners any favors when you could just as easily build a spring and design a suspension exclusively for the Excursion. Make a better setup then the procomp 22210/22415 combo and I will be happy to recommend it. But your junk yard setup is not going to earn my stamp of approval when better options are easily available.
Old Apr 27, 2019 | 02:35 PM
pirate4x4_camo
If a new suspension isn't in the budget and your current springs are not sagged then for $200 consider a new set of the KYB Mono Max shocks.
I have provided links to all the parts you need and narrowed it down to 2 vendors for the Procomp 22210/22415 setup that will put your ride height at 27". ( 4" over stock)
this rides great on the highway and performs excellent off road and will clear 35's
this setup eliminates the rear block which reduces axle wrap and the need for a rear sway bar
plus it increases caster and corrects the driveline angle, this will make it track straight and true and completely eliminates wander. ( assuming the rest of your steering is in order )
Total cost $1074 complete
Front Procomp leaf springs 22210 $90 each
Amazon Amazon
Rear Procomp Leaf 22415 $106 each
Amazon Amazon
Zone adjustable Track Bar $100
Amazon Amazon
Bilsteins 5100 shocks
Front $180 pair
Amazon Amazon
Rear $156
Amazon Amazon
Ubolts
Front $54
https://www.wfoconcepts.com/pr/Front...ts/19732/16883
Rear 8’’Ubolts x 3.5” round $47
https://www.wfoconcepts.com/pr/WFO-I...ts/19732/16924
3’ Spring Plate rear $38 pair
https://www.wfoconcepts.com/pr/3-Lea...rd/16828/17035
Front 3’ wide 2* shim $35 pair
Rear 3” wide 2* shim $35 pair
https://www.wfoconcepts.com/cr/3-Inch-Axle-Shims/4384
Old Apr 27, 2019 | 03:46 PM
WE3ZS's Avatar
WE3ZS
Originally Posted by pirate4x4_camo
this is what a B or C f250 spring looks like when installed on a Excursion ...
notice the lack of gap between the main spring pack ( top 4 leafs ) and the very bottom overload spring.
on a f250 this gap is over 4 inches
This is how a dual rate spring is designed to work on the F250,
notice the gap gap between the main spring pack and the overload spring.
Referencing those two pictures, it looks like the Ex is sitting on it's tires and the F-250 is on a lift with the suspension at full droop. Not the "perfect" comparison as it tilts the scenario more towards the pickup, even though the facts support the argument the weight being on and off the springs is a bit of apples vs oranges.
My "modded" B codes don't sit quite as flat as the ones shown, but I guess those two reused EX bottom leaves are helping with that. Unloaded mine definitely doesn't ride like a Caddy but since most miles driven are with 6K+lbs on the rear axle my Frankenstein setup is getting the job done. Replacing the whole works with the other option and air bags sounds like it would offer a better ride but it will be a while before I have an extra $1k that I'm willing to throw at it to find out, too many other projects waiting on the extra cash list here.
Mine.
Old Apr 27, 2019 | 05:09 PM
Jregezeino's Avatar
Jregezeino
Mine.
mine looks similar to yours, overloads leaves are a good 1-1.5” from the leaf pack while resting on the ground. Very happy with the V/mod B setup from ATS.
Old Apr 27, 2019 | 05:49 PM
pirate4x4_camo
The Modded rear pack is a whole different scenario.
Oh and I don’t know if that pic was taken on a lift or jack stands but either way it was just meant to illustrate the gap. We know from the graph that the gap is 4.6” of travel at curb weight ride height.
Tom,
i would love a pic of your rear springs when you are fully loaded but it looks to me like with the additional 2 bottom leafs that your spring would have to go well past inverted to actually fully engage the pack to contribute it’s full spring rate.
for the most part it seems to me the way you have it configured so that the overload leaf is just a block.
( although there is some additional rate being added by the contact with the bottom Ex leaf.
Your main pack spring rate is very likely similar to the stock excursion since the top 4 springs from the F250 are the of similar dimensions to the Excursions then by adding the bottom 2 leafs from the Excursion it likely puts you right at the stock 410 pounds per inch but now with 7 inches of travel.
if you multiply the 7” of travel by a spring of 410 pounds per inch that would give a capacity of 2870 per spring or 5740 total which as you know exceeds the rear axles 5250 pound rating. We could calculate how much spring Your overload is contributing by measuring the amount of contact it makes with the very bottom Excursion leaf when fully compressed but what ever it will likely be a moot point since without it you are already well over the axles rating
Old Apr 27, 2019 | 05:56 PM
pirate4x4_camo
see above post, the modded B pack is going to be almost indistinguishable from stock because it is the stock spring rate just has more travel giving you more capacity then you have axle to handle. ( doesn’t stop us from doing it )
which going back to my statement that by adding longer travel allows the use of a lower spring rate to improve the ride and handling which you can use unlike your now higher capacity.
Old Apr 27, 2019 | 08:02 PM
pirate4x4_camo
Originally Posted by ATS Junior
“I can use a couple of blocks of wood and make a Excursion owner happy compared to a clapped out stock suspension”
This is what I’m taking about. No you can’t
-Junior
care to make a wager on that statement ? Say $100 bucks ?
anybody in Northern Ca have a stock Excursion with a clapped out ( sagged an inch or more ) rear suspension I can borrow to settle a friendly little wager ? ( only caveat is you can’t know Me or ATS, I will return it back to clapped out , after you judge the ride quality )
Old Apr 27, 2019 | 08:13 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
You're funny Camo. I’d rather not bet on someone’s safety so you can try and make a point about raising ride height with wooden blocks so the truck doesn’t hit bump stop or frame.
Old Apr 27, 2019 | 08:43 PM
pirate4x4_camo
I assure you I would never jeopardize somebodys safety over a bet and I promise the suspension will move as Ford intended including hitting the bump stop as it was designed to.
oh and I am serious so if want to continue to underestimate a retired guy with lots of time and money on his hands that has a life long career and passion for designing, fabricating and racing suspensions I will be happy to take your money. .
Old Apr 27, 2019 | 09:32 PM
EXSwap's Avatar
EXSwap
Subscribing for all the part numbers as I still have a few things to pick up for my procomps. Thanks!
Old Apr 27, 2019 | 11:46 PM
Jregezeino's Avatar
Jregezeino
Though I’m satisfied with my X/Mod B codes (mentioned V codes earlier but was mistaken) from ATS, I am curious about how the ProComps would stack up against what I’ve got. The ride is nice, just wish now that they’ve settled out that I had another 1.5” or so of height like it was 5k miles ago with new springs.
The front shackles are within an inch or so of contacting the frame rail again, similar to how they were with my stock springs, the X codes have nearly flattened out since I’ve been driving on them. Maybe it was addition of my 200# ranch hand grille guard that overdid it, I don’t know? Maybe the “modified Xcode” would have been more appropriate, again or possibly the ProComps.
Old Apr 28, 2019 | 12:36 AM
pirate4x4_camo
all leaf springs sag with usage, how much they sag and how long until they sag is a matter of the materials and processes used in their manufacture and how they are used. But if they sagged 1.5” in 5k miles that would be a cause for concern.
on the Excursion stock springs I recommend replacement at 1” of sag.
The V-10 Ex came with a spring rate of 350 lbs inch in the front
the Psd Ex came with a front spring rate of 380 pounds per inch.
V codes are 430 pounds per inch
X codes are 470 pounds per inch
the procomp 22210 has a rate of 430 pounds per inch.
If you have a v10 and assuming your ranch hand weighs around 200 pounds more then a stock bumper then with a ranch hand installed it will compress a set of procomp 22210 .28” and will compress the X codes .21” more vs the stock bumper.
i don’t think your sag issue is a matter of your spring rate, it sounds more like a quality issue.
Old Apr 28, 2019 | 12:46 AM
  #28
Jregezeino's Avatar
Jregezeino
I am a 7.3 psd, and the brush guard was 225# measured before I bolted it on, the springs feel great...nice and plush. My measurements however have lost 1.5” since new.
I’ve been trying to figure this out, but it shouldn’t be physically possible for the shackles to contact the frame so long as the springs aren’t longer than stock, right? I do have good condition bump stops installed just in case it ever decides to bottom out.
Old Apr 28, 2019 | 12:55 AM
  #29
pirate4x4_camo
I edited the 350,,,,, I read your 200 pounds but typed 350 pounds because I was looking at v10 spring rates.
200 pound ranch hand would compress the psd springs .26”
no the shackles should not hit the frame... post a pic
Old Apr 28, 2019 | 05:58 AM
  #30
WE3ZS's Avatar
WE3ZS
Tom,
Well, for the next 21 days we will be on the road so snapping a picture of the rear springs loaded shouldn't be a problem as long as my soggy brain can remember to do it. My scale ticket from a weekend trip shows 6220lbs with WD and 6920lbs without WD so with this longer trip those will be a little higher.
I know that's over the axle rating of 5250lbs (on the sticker) but I've seen Sterling 10.5" axle ratings variously listed at 6830, 7200 and 7600, so many number out there floating around it gets muttled sometimes, what's the real Sterling actual axle rating?
