Door latch Bolt and roller.
Iam usually on the Diesel section but not much going on, so wondered over here to see what`s up.
I`ll add my 2 cents on my door striker problem. My 86 F-250 doors were hard to shut and slightly rattled.
New door seals would probably be a big help. I had read about using the Pex pipe trick. At HD only
available length is 4ft or so, and comes in colors....and pink didn`t cut it. so went with white.
Easy to cut it, using a PVC pipe cutter plyers. Then placing it vertically in the jaws, cut it length wise.
Hard part was to pry it open enough to fit over the bolt.
Did make a huge improvement in shutting the doors.
Later on I was at PNP rapeing parts off a 85 F-250 6.9, wondering around the yard noticed the later model
trucks say in the 90`s had some good looking Strikers especially on the passenger side. Had my HF Earth
Quake 3/8" battery Impact gun, and using a T50 bit, grabbed a bunch of strikers. Replaced the Pex ungraded
ones and the doors seem to shut much better. Does not take much effort to close the doors.
The later strikers have that bent piece of steel around the Striker probably so people don`t get their clothing
hung up on the Bolt.
My Bro in Law has an old 83 4x4 that has been rode hard one too many times. He really has to slam the doors to
get them to close. His excuse is the prior owner replaced the door seals with cheap Chicom ones that are thicker.
I didn`t buy that excuse, so one day I got with him and replaced them with the PNP one`s and it was night different.
No more slamming.
Be sure to mark the old striker with a pencil for reference, then make adjustment from there.
Any one wanting a HF impact gun, be aware that the sockets are held on with a steel ring on the end of the snout of
the gun. I haven`t used mine all that much, but was having trouble taking off or on the socket. The ring was bent and
sticking up after getting the socket off. Had to use a slotted screwdriver to pry the socket off.
W/O the ring, the sockets will not stay on.
If I had bought the $29 warranty, they would have replaced the gun. Still can purchase the warranty. That is a pricy
little ring. Maybe a rubber "O" Ring might hold it on...we`ll see.
My battery tools are Dewalt, and notice the Dewalt gun has the little button that holds on the socket, much better deal.
I was going to buy the 1/2 gun from HF, but not now. better off having one brand of tool, then you only need one battery
instead of multiple brands.
Charlie
https://www.amazon.com/gp/product/B000COB5LM/ref=ox_sc_act_title_3?smid=ATVPDKIKX0DER&psc=1&tag=viglink20368-20
No more slamming.
Charlie
If and when it fails I have the PEX and the silicone self fusing tape on board so I can make a road repair very quickly. Next time I go to a PNP I'll look for some spare rollers too. It's probably the best fix available. I didn't want to go with the current after market replacement with the angle brace. It just didn't look right to me.
BB2
Even though such a repair may seem hokey, it has held up very well. I did the first one out of desperation in the middle of a long trip, to keep the door from rattling. I didn't put much thought into it and planned to get the correct part when I got home. Much to my surprise, it worked wonderfully. When the piece broke on the other side, I didn't think twice and did the silicone tape trick again.
I thought the hinge came with new roller... But now I realized were talking about two different rollers lol.
I forgot to mention a trick with self-fusing tape. If you pull tight during installation, it stretches thinner and becomes denser. You'll need to make another wrap or two to compensate for the reduced thickness, but you end up with a very firm consistency. Conversely, if not stretched so much, the end result has a little more give. You can adjust to suit.
We'll see how long the bandaid lasts!
BB2
Roller as the Bushing is being refered to I guess is not is not something that can be taken off
a striker. I think that is the way I read it above they can be removed.
I agree if the door hinge is worn out and the door sags, then it will add wear to the bushing as
it closes and pulls the door up to latch.
both of mine sag. But I have new PNP doors to replace the rusted banged up doors I have.
When PNP has their 50% off sale the whole door is $30 something dollars. If the hinges are
good, then they stay with the doors. Think I have 5 doors so far. Hard to find good doors by
the time PNP beats up the bodies moving the vehicles around with the fork lifts.
Charlie
Charlie
Charlie
Charlie
BB2
Wow almost year n half ago last posting.
I just reread this thread, and it s mentioned that the Striker plastic roller piece
is not removeable. Well it is on some of the later vehicles maybe in the 90`s.
Don` remember years, but check on vans, PU`s etc.... some I have removed
the bolt, it will unscrew from the bent metal piece. This style.
Not all of them will unscrew, but some will. The one`s that will, I remove the plastic
roller and keep it. Passenger doors, some Van Sliders as I remember and then the
the rear Hatch Door I think the Explorer`s. ? Just wonder around your local PNP
with your electric impact gun and a T 45 bit. (Think that is the size?)
The one`s on my 86 F250 I put on a couple year back are holding up. Can`t beat
PNP Auto Supply Haven`t been in there for quite a while.....need my theropy...LOL
Here is a thread from a couple weeks back on the same topic.
https://www.ford-trucks.com/forums/1...-bushings.html
Charlie
Charlie
Pastmaster
09-18-1999 07:30 AM
