Towing Capacity
Old Apr 25, 2019 | 09:41 AM
Jonathan LaFountaine's Avatar
Talking Towing Capacity
I have a 71 F100 360 v8 long bed, does anyone know how much I can haul or tow. Thank you
Old Apr 25, 2019 | 10:11 AM
ford390gashog's Avatar
ford390gashog
Well to figure out your hauling you need the base curb weight, so go scale it. Then subtract your base from the GVWR and that is your hauling, the towing on these is limited to less than 3500lbs and I would not even push that number with a F100.
Old Apr 26, 2019 | 11:09 PM
351Cleveland C4's Avatar
351Cleveland C4
Nothing was ever published.... so, load it up!
Old Apr 26, 2019 | 11:13 PM
351Cleveland C4
In reality, you can tow quite a bit IF you have the know how and proper equipment. I've towed quite a bit with my F-100, and I've learned some things doing it. 6,000lbs id take almost anywhere, over any distance. 8,000 is pushing it, limited distance and only across flat ground. And the few times that I've done 10,000lbs or more have really not been that enjoyable.
But I built the truck for towing and hauling. It has 4.11 gears and other mods to help it handle the extra load. For a regular old F100 that's all stock and somewhat worn out, I wouldn't push it passed 4K. (A small car on a car trailer)
Old Apr 27, 2019 | 12:35 AM
GreyScar's Avatar
GreyScar
And make sure you not running "P" tires...........
Tom C 56
2010 - 2014 Ford SVT F150 Raptor
Jan 21, 2022 09:13 AM
jpdover
20
Jul 20, 2014 05:41 AM
fasthufi
Nov 24, 2009 02:36 PM
Mecinoid
N. California Chapter
46
Oct 16, 2007 01:56 AM
dotty
All Things Towing
May 10, 2003 12:13 AM
