Pros and Cons JAG, Vette and other IFS
Old 10-02-2003, 05:39 PM
fatfenders's Avatar
fatfenders
fatfenders is offline
fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.
Here's where you discuss Jaguar and Vette IFS options for F1/F100. Or any other IFS I might have forgotten. Any and all are welcome. If a particular system discussion gets going, we'll pull it over into it's own thread if needed.
Pros
1. Donor is a performance car of substantial weight.
Old 10-03-2003, 11:29 AM
QuickerPickerUpper
QuickerPickerUpper is offline
QuickerPickerUpper is starting off with a positive reputation.
I am particularly interested in this subject. Hope to see some input from people with first hand experiences. Seems like a hot set up, but alittle more expensive.
Old 10-03-2003, 08:00 PM
286merc
286merc is offline
286merc is starting off with a positive reputation.
Pros
2. Jags of the 80's are dirt cheap in the rust belt as the unibodies are rotted out. I also believe (need to check before saying too much) that the brakes and stuff are stock GM.
3. Vette parts will always be available albiet pricey.
4. Jag is a complete subframe car, same concept as the GM's used in Effies.
5. Jag is owned by Ford
Cons:
1. Hi Tech look may not be to everyones liking
2. Jags are wide, may not fit without serious work. The only How-To I have is for a 50 Chevy 1/2 ton.
3. Vette donors not very common.
Old 10-03-2003, 08:08 PM
ferguson777's Avatar
ferguson777
ferguson777 is offline
ferguson777 is gaining momentum as a positive member of FTE.
Anyone,
I recall jag rear ends (of course) and to a lesser degree Jag front IFS being the hot ticket in the 70's but I don't recall anyone offering a kit to adapt the Jag IFS back then, nor have I noticed anyone offering a kit now. Am I correct in assuming that one is on his own relative to rigging a Jag IFS install?
For anyone that has never seen it - the Jag IFS components have a very light (not to imply weak)and sleek appearance to them. However, it is my understanding that repair parts are mucho dinero.
I know that at least one outfit offers a kit for putting the Corvette IFS (and IRS) into trucks -
Don McNally - Flat Out Engineering,
Orange, Calif.
714-639-2623
per page 88 advertise in Classic Trucks, issue from Nov. 2003.
No mention in ad of prices, applications covered, etc.
Later,
Old 10-04-2003, 11:44 AM
51dueller's Avatar
51dueller
51dueller is offline
51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.
TCI will set up one of there frames for 28-48 cars to work with a jag rearend. You just need to specify the degrees.(don't what that is though)
Old 10-05-2003, 10:10 AM
ferguson777
Another source for kits to adapt Corvette IFS to 48-52 and 53-56 (sorry no 57-60) Ford trucks is Progressive Automotive (jus stick ".com" behind the name to get to their website.
Basic kit using all your donor car parts start around $730. USD. A complete hub to hub package runs around $2,400.00 USD.
The Vette set up has the same sleek, light and airy appearance as the Jag. (Again, not implying it's weak set up).
Later,
Old 10-06-2003, 07:11 PM
ferguson777
Gonna be pretty hard to do an overview of this paltry bit of info. Come on, Anyone got a cousin or a mother-in-law that has done one of these? Help us out here.
Throw me a fricken bone, here!
Later,
Old 10-06-2003, 09:02 PM
fatfenders's Avatar
fatfenders
RMF
Vettes are Chevys, that's very bad
What else you need?
Seriously though, we have two choices. Obviously one is just skip it for now. Another is to dig up the CT or CTT article. There is plenty of info in there. Which issue was it in PJS55 John?
Old 10-09-2003, 08:01 AM
ferguson777
Carl,
Two questions -
1. Were you able to confirm whether or not the Jag brake components are/were in fact GM parts?
2. even though it's for a GM application, any possibility you might be able to scan the Jag how to article and email it to me?
Otherwise, we have no data at all relative to the Jag set up.
Thanks,
Old 10-09-2003, 08:59 AM
286merc
286merc is offline
1. I'll ask around on some of the other forums I hide at.
2. Now, all I have to do is find which pile and folder that article is in.
Old 10-09-2003, 07:10 PM
fatfenders's Avatar
fatfenders
Please try ask as soon as you can Carl. This one is going to hold us up if we don't get info soon. If you can't, that's OK too but we want to include it for you if we can.
Old 10-10-2003, 09:02 AM
286merc
286merc is offline
It may take a bit of time to get the info as Im now asking around in the UK and Australia about the Jag.
If you cant wait so be it.
Old 10-10-2003, 11:18 AM
286merc
286merc is offline
Here is some stuff. Altho showing a 46 Merc and 42 1/2 ton it is a start. Im still looking.
http://www.geocities.com/hotrodder1938/chopper.html
It also appears that the brakes are not GM but Ive got to stop at a friends and check out his later Hollanders.
Old 10-10-2003, 09:37 PM
ferguson777
Carl,
They're sure not a pretty as I remember them. Listen, don't put any more effort into it. Obviously there aren't many folks still doing the Jag IFS anymore.
Thanks for your efforts thus far though.
Later,
Old 10-11-2003, 11:18 AM
286merc
286merc is offline
The pretty ones were from the old XKE days.
One of the best features of the XJ6 style is that the complete crossmember and all simply unbolts from the frame. So the install on another vehicle involves removing the old, fabricating new mounting brackets and bolting it up.
As Im intrigued anyway Im still gathering info and leads. Found a company in the UK that supposedly knows all about them and Ive sent off an EMail.
Quick Reply: Pros and Cons JAG, Vette and other IFS
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
