Center caps for the 8 lug F250
Hello,
as summer is coming around I want to make my truck a little more shiny. One thing that is quite the eye sore are the dirty and slightly rusted middle of the wheels in front and back. So I thought about getting some center caps. Preferably original. The problem that I have run into is that I can't seem to find what the original center caps for 8 lug wheels looked like. Did they not have any?
I like the look of the red for the 5 lug, but there doesn't seem to be any for 8 lugs.
I would welcome any recommendations for center caps that would look close to original as well.
Thank you.
Thank you.
Hello,
D8TZ-1130-C .. TYPE 5 Hub Cap - 12 5/16" diameter - Matte Finish // D8TZ-1130-D .. TYPE 5 Hub Cap - 12 5/16" diameter - Bright Aluminum Finish.
Q!!
These are 15" wheel covers that were originally used on 1971/72 Galaxie/LTD & 1973/79 F100 2WD, 1975/79 F150 2WD
To install them on 1972 and later F250/350's with 16" wheels, D2TZ-1210-A 16" Trim Ring was required.
The trim ring was snapped on the wheel FIRST, then the wheel cover was snapped onto the trim ring, I kid you not!
I'm in the same boat...
I'm not sure that 8 lug hubs ever had any hub covers.....only wheel covers.
I once did a fanatical search on Google looking for a stock truck with 8 lug hub covers....and never found a stock truck that had any.
Also note that hub covers and wheel covers are different if you have 4x4 or 4x2.....the fronts will either have a cutout or removal clip on the 4x4.
Steven
Steven
slim chance ranch
12-26-2014 11:13 AM
Hearseguy
06-04-2014 09:12 PM
