2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Need 2017 F350 rear hitch shackles
Old 04-21-2019, 10:48 AM
DJP6371
DJP6371 is offline
DJP6371 is starting off with a positive reputation.
Where do I find the right sized ones?
Old 04-21-2019, 11:30 AM
flatlander2441
flatlander2441 is offline
flatlander2441 is starting off with a positive reputation.
I've seen on this forum 5/8 from amazon ?
Amazon Amazon
Old 04-21-2019, 12:18 PM
jbrnigan
jbrnigan is offline
jbrnigan is gaining momentum as a positive member of FTE.
https://www.amazon.com/s?k=5%2F8+sha...b_sb_ss_i_1_12
I used a grinder to trim the casting line on the interior "eye" of the shackle for add'l clearance, on the right side only.
Old 04-21-2019, 12:54 PM
jimzpsd's Avatar
jimzpsd
jimzpsd is offline
jimzpsd is gaining momentum as a positive member of FTE.
I've seen many of those hanging on trucks, and most become rusty along with the hitch....then it spreads,..no thanks.
Old 04-21-2019, 01:41 PM
wb6anp
wb6anp is online now
wb6anp has a great reputation on FTE.wb6anp has a great reputation on FTE.wb6anp has a great reputation on FTE.wb6anp has a great reputation on FTE.wb6anp has a great reputation on FTE.
Old 04-21-2019, 04:52 PM
09FX-4's Avatar
09FX-4
09FX-4 is offline
09FX-4 is starting off with a positive reputation.
5/16 clevis hooks fit in the slots. No need for something else hanging there.
Old 04-21-2019, 05:32 PM
zekes66
zekes66 is offline
zekes66 is starting off with a positive reputation.
I use hammerlocks and just give them a spray of Fluid Film from time to time so they dont rust.
Old 04-21-2019, 07:31 PM
jbrnigan
jbrnigan is offline
When not towing I remove mine (30 sec). A dab of never seize on the threaded pin and eye..........not always, but, some rust is just the result of neglect.
Old 04-21-2019, 07:39 PM
Crabbman P
Crabbman P is offline
Crabbman P is starting off with a positive reputation.
The shackles I bought at Tractor Supply were galvanized, not likely to rust easily. Besides, I also remove them when not towing. Don't want them bouncing and rattling around.
Old 04-22-2019, 05:39 AM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.
I use galvanized 5/8" shackles. No rust, no rattle.
Tighten with pliers so no one with sticky fingers can walk away with them easily.
Old 04-22-2019, 10:09 AM
BigTexDiesal
BigTexDiesal is offline
BigTexDiesal is starting off with a positive reputation.
Use a die grinder and trim the horizontal part a little. Tons of meat. Horrible design by Ford....
Old 04-22-2019, 11:40 AM
landman873
landman873 is offline
landman873 is starting off with a positive reputation.
I would not call it a horrible design. That's that amount of metal it takes to pass safety testing. So in reality you should prolly blame others. We all know how cheap the manufactures are and they wouldn't spend any extra pennies if they didn't have to.
Old 04-22-2019, 12:18 PM
jbrnigan
jbrnigan is offline
FWIW - Before purchasing shackles (posted pic earlier), for the same dough, I could have just changed the safety chain hooks to fit the hitch openings.
Old 04-22-2019, 12:39 PM
1956Fatfenders's Avatar
1956Fatfenders
1956Fatfenders is offline
1956Fatfenders is gaining momentum as a positive member of FTE.
Another hammerlock user here. Had them powder coated to help them look good a little longer. Word to the wise, take them off before renting a U-Haul trailer. U-Haul's safety chain s-hooks are don't fit my hammerlocks and are very difficult to sneak through the hitch openings with the hammerlocks in place.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
