Go Back  Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Reload this Page >
Just checking... IP gear can't jump teeth inside the housing, right?
Old 04-20-2019, 06:54 PM
119er
119er is offline
119er is starting off with a positive reputation.
So I have my pump and injectors off being rebuilt at the moment. I was installing new GP's and decided to clean the bores and threads on both the GP and injector bores. As I blew air into the one of the bores, the engine rolled over and the pump gear moved, obviously. I lined my witness marks back up, but it shouldn't matter anyway, right? Gear rotated 20 degrees or so counterclockwise. Just checking that it can't somehow jump time.
Old 04-21-2019, 03:12 AM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
hairyboxnoogle has a good reputation on FTE.hairyboxnoogle has a good reputation on FTE.hairyboxnoogle has a good reputation on FTE.
Nope. I tried it on mine when i was putting it together just to see if you could. Furthermore, you have gravity on your side in this situation.
Old 04-21-2019, 10:44 AM
119er
119er is offline
Thanks for the reassurance. I was positive that it couldn't, but I am making a lot of changes at once. Should I have any issues getting up and running, I didn't want that in the back of my mind.
Old 04-22-2019, 09:37 PM
hairyboxnoogle
Other than a little air from having the pump off, should roar to life just fine.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
