Torque Pro temperature gauge variations
I just installed Torque Pro for my 2019 F350 6.7. I noticed the transmission temperature on Torque Pro varies from 5-15 degrees from what the dash gauge reads. The engine oil temperature is pretty much spot on with only a 1 or 2 degree difference between the dash and Torque Pro. Anyone have an idea what's up with the transmission temperatures? Also, which EGT temp do I want to be watching? I see there are 4 different sensors.
The transmission temp on the dash might be dampened...averaged....and not vary like the torque pro...the torque pro reads the temp sending unit and displays the temp at that moment....i would not worry about the variation as much as the upper temp reading value
the water temp doesn't vary as erratically as the trans. the trans only send fluid to the cooler when needed, not all the time.
I monitor 13 and 14....they are more of an indicator to me when the truck is in regen (active and passive) or not
https://www.dropbox.com/s/m3fwxhqw1fr73i0/TestSD4-19.apk?dl=0
U have to allow install from not approved locations. The after install in TP go to manage plugins, to add them to the list to use
I'm struggling here a bit. I got the above file downloaded from Dropbox, but I can't seem to figure out how to load it in to Torque Pro. I see the "manage extra PIDs/ sensor" button is, but the only option I can see is the Ford specific button. Nothing that allows me to add the Dropbox file.
Once u install, then u can select it in torque pro as u tried
If the install option is enabled when u click the dropbox link, it will launch install automatically
You have to install it like an application (app). But to do that with apps not from the app store u have to enable "install from u known sources". (Use search in settings)
The soot and distance since last Regen (calculated)
do not work on 17's up due to removal of the pids. We are searching for another method
So you have to install from your home computer and not from your phone? Been having the same issue of not being able to enable the apk file from Drop Box. I get file not found when trying to add by my phone
