1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
COP/plug upgrade on '99 5.4 or no?
Old 04-19-2019, 04:25 PM
kcducttaper's Avatar
kcducttaper
kcducttaper is offline
I've got a 2v 5.4 with 65k miles that has developed a fairly predictable misfire in cylinder #1 when going up a hill. Instead of replacing the stock COP with another stock unit that will probably fail again, I'm considering upgrading all 8 COP's to something with a bit more spunk and perhaps going with iridium plugs for the sake of (hopefully) not having to mess with them again for the next decade or two. Is there a preferred COP 'upgrade' for the old 5.4's or am I just as well off replacing with the stock units?
Old 04-19-2019, 04:26 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Your only chance for good performance and reliable performance is the genuine Ford parts.
Old 04-19-2019, 10:01 PM
Squisher's Avatar
Squisher
Squisher is offline
Yup. When I had issues with my 03 it was the plugs not the coils
Old 04-20-2019, 07:01 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
You'd be wasting your money. If you need new plugs and boots, install them. If you have a failed COP, replace it.
I guess that's why, after 7 years, those two $15 Rockauto COPs I installed to cure misfires with the OEM COPS, are still working fine....
Old 04-20-2019, 08:14 AM
FractureCritical's Avatar
FractureCritical
FractureCritical is offline
but that doesn’t matter. The forum has declared that Ford OEM is the only path to success. All other paths are wrong and therefore doomed to fail. If the forum has so declared it, it must be so. Woe be to those who challenge the dogma of the forum.
But like you, I’ve been running perfect for years on aftermarket COPs and boots
<GASP!>
Old 04-20-2019, 10:01 AM
kcducttaper
I may pick up a set of aftermarkets one of these days and go iridium. Yeah, they're expensive, but they're so obnoxious to replace that I wanted to punch the engineers in the spleen when I put new plugs in ~3 years and 20k ago. I'd rather spend some coin and never have to screw with them again.
Old 04-20-2019, 01:37 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Oem coils on Amazon $220 to your door last time I checked. Stock plugs have always worked the best...
Do what you want but I have heard it all since 2003..
Old 04-21-2019, 08:12 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
171k on my 5.4 super duty , and it's still running all 8 original Ford COP's. So IF one finally fails I'll be buying a new Ford COP and not some crap aftermarket unit. And I only install motorcraft plugs also, ever 30k
Old 04-21-2019, 09:58 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
99 Triton V10 with 166k miles and two new COP's, Motorcraft and Denso, which are the same. Why mess with something that works.
Old 04-21-2019, 11:28 AM
redford's Avatar
redford
redford is offline
Received 1,562 Likes on 910 Posts
All the COP does is step up the voltage pulse.
Say the stock COP has 12v at 10 amps input, and the COP steps it up to 1200v, it'd be 1200v at .1 amps. Either way, it is 120 watts of power. The wattage remains constant.
An aftermarket COP might step up the voltage even more, but at less amps. Say it jumps the voltage to 12,000v, you would have .01 amps.
Old 04-21-2019, 05:42 PM
projectSHO89
The secondary voltage will only rise to the point where the plug fires, it can rise no higher unless the plug gap is increased.
Skatermike24
05-09-2017 12:12 AM
coolfeet
36
09-29-2014 09:08 AM
riverking
08-24-2014 06:55 PM
97F250LD
Modular V8 (4.6L, 5.4L)
03-19-2007 06:27 PM
boatcop1
05-19-2006 09:43 PM
Quick Reply: COP/plug upgrade on '99 5.4 or no?
