COP/plug upgrade on '99 5.4 or no?
I've got a 2v 5.4 with 65k miles that has developed a fairly predictable misfire in cylinder #1 when going up a hill. Instead of replacing the stock COP with another stock unit that will probably fail again, I'm considering upgrading all 8 COP's to something with a bit more spunk and perhaps going with iridium plugs for the sake of (hopefully) not having to mess with them again for the next decade or two. Is there a preferred COP 'upgrade' for the old 5.4's or am I just as well off replacing with the stock units?
Your only chance for good performance and reliable performance is the genuine Ford parts.
But like you, I’ve been running perfect for years on aftermarket COPs and boots
<GASP!>
I may pick up a set of aftermarkets one of these days and go iridium. Yeah, they're expensive, but they're so obnoxious to replace that I wanted to punch the engineers in the spleen when I put new plugs in ~3 years and 20k ago. I'd rather spend some coin and never have to screw with them again.
All the COP does is step up the voltage pulse.
Say the stock COP has 12v at 10 amps input, and the COP steps it up to 1200v, it'd be 1200v at .1 amps. Either way, it is 120 watts of power. The wattage remains constant.
An aftermarket COP might step up the voltage even more, but at less amps. Say it jumps the voltage to 12,000v, you would have .01 amps.
coolfeet
36
09-29-2014 09:08 AM
