93 5.0 EGR tube question
Old 04-19-2019, 03:19 PM
e1p1's Avatar
e1p1
e1p1 is offline
e1p1 has a good reputation on FTE.e1p1 has a good reputation on FTE.e1p1 has a good reputation on FTE.
(Edit for those with short attention span: It was Code 33 and the fix this time was an EGR Control Solenoid.)
OBDI throwing a code for EGR flow I think it was. EGR diaphragm holds vacuum and pintle moves freely. Vacuum hoses replaced. Haven't tested EGR solenoid yet.
When I had the EGR removed, the EGR tube that goes to the manifold seemed loose. Since I can't see the other end, I'm wondering if that's normal? Or indicative of breakage or coming unseated?
Thanks. Been a long time since I've hung around FTE, good to still have y'all here.
Old 04-19-2019, 03:20 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
EGR flow error isn't possible for that year truck so what was the exact code you got?
The EGR tube has a flex joint in the middle it may feel loose when disconnected but as long as the loose end doesn't turn it's OK.
Old 04-19-2019, 03:36 PM
e1p1's Avatar
e1p1
e1p1 is offline
Wow, thanks for the fast response. Ill go retrieve the codes again.
Old 04-19-2019, 04:43 PM
e1p1's Avatar
e1p1
e1p1 is offline
OK...
Code 33 both with engine on and off. Truck runs pretty good, maybe a slight stumble when I floored it in the second test.
This thread: https://www.ford-trucks.com/forums/8...code-33-a.html looks like a good place to start. Any other insights? Maybe just throw money at it and put a new egr on?
Old 04-19-2019, 07:09 PM
Conanski's Avatar
Conanski
Conanski is offline
Is there any vacuum on the EGR line at idle? Should not be. The code suggest the valve isn't opening when commanded or the position sensor isn't reporting correctly, so the problem is likely either the control solenoid, the vacuum line, or the position sensor.
Old 04-19-2019, 10:42 PM
e1p1's Avatar
e1p1
e1p1 is offline
No vacuum at idle on EGR line. Looks like I'll have to find my digital multimeter and play with some of that. After double checking the vacuum lines.
Old 05-03-2019, 07:27 PM
e1p1's Avatar
e1p1
e1p1 is offline
It was the EGR Control Solenoid. And likely a sticky pintle on the EGR valve.
Thanks Conanski for the quick replies and info.
I'd like to say it was my stellar diagnostics that won out, but due to time circumstances I went out and bought a position sensor and vacuum solenoid and installed the position sensor first...no luck. Installed the solenoid and poof, the check engine light stays off.
I did check the ability of the EGR diaphragm and the vacuum canister to hold vacuum...both did. And recall I did remove the EGR valve and found the pintle movement to be sticky and not fully moving, and fille dit with carb cleaner for a couple hours, drained and dried it, and sprayed it with some WD-40. Works smoothly now.
FYI, bought a Harbor Freight vacuum tester and brake bleeder on sale for $24. that helped.
For anyone who might troubleshoot similar EGR issues, maybe pull the vacuum line leading to the EGR...it looks like it runs around back of the engine and goes into the control solenoid. I'm thinking I could have plugged one end and used the vacuum tester on the other to test for holes in the line.
Old 05-03-2019, 08:26 PM
dziwei
dziwei is offline
dziwei is starting off with a positive reputation.
Is it possible it was code 332? I had that one related to EGR on a '95 w/ 302.
Old 05-04-2019, 12:05 AM
McLeod's Avatar
McLeod
McLeod is offline
McLeod has a good reputation on FTE.McLeod has a good reputation on FTE.
My 93 spits out three digit code DTCs
Old 05-04-2019, 08:43 AM
ZombieF150's Avatar
ZombieF150
ZombieF150 is online now
ZombieF150 is starting off with a positive reputation.
93 should be 3 digit code. Mine is. you may be reading a 332 as 33-1-1
Old 05-08-2019, 06:22 PM
e1p1's Avatar
e1p1
e1p1 is offline
Was for sure a 33. KOEO AND KOER.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
