92' and newer eletric speedometer swap to older
Old 04-19-2019, 01:05 AM
b1jetmech
b1jetmech is offline
b1jetmech is starting off with a positive reputation.
I just did a ZF5 swap to my 88' F350...however, it was a 92 and newer Zf5 speed without the speedometer port.
Does anyone know how to wire in a en electric speedo from a newer truck(92-97)???
Much appreciated!
Old 04-19-2019, 02:46 AM
frank5079's Avatar
frank5079
frank5079 is offline
frank5079 is starting off with a positive reputation.
I found this link....it might apply to your speedo problem.
https://www.thedieselstop.com/forums...e-gear-149028/
Old 04-19-2019, 06:23 AM
subford's Avatar
subford
subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Much appreciated!
Just tap into the ABS sensor wiring from the rear end under the dash at the ABS module. Then wire in both of the power wires and ground.
That should do it.
Images for wiring:
Old 04-19-2019, 05:49 PM
b1jetmech
That should do it.
Images for wiring:
Hey, thanks for the reponse and the diagrams! Hopefully, I'll have it installed and working this weekend.
Old 04-20-2019, 08:09 AM
Eddiec1564
Eddiec1564 is offline
Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.
Here's a thread about how to do the swap: https://www.ford-trucks.com/forums/1...-issues-2.html
After getting the wiring figured out, you just have to cut up the old cluster to fit the 92+ speedo in place.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
