New 347 Stroker Install 95 f150 EFI 5.0 2wd truck. Chip Suggestions?
As in the title I have just installed a 529hp/ 502tq 347 Stroker. I was told my stock ecu should at least run the new motor. However due to pretty radical build (custom ground 576 cam, lift 110 separation, AFR 205 Heads. Scat forged bottom end ) I can’t get my truck to idle. It will start with WOT. Then you must feather the pedal to keep it running. And it’s RICH. Did I say RICH? 42lb Bosch injectors, and 80mm Pro-M MAF calibrated for 42lb injectors. Seemed to be zero vacuum leaks. I called Compcams and they advised the custom cam I had was on the verge of not being a daily driver Due to the cam. After a second attempt to start the engine 2 days later, it fires right up but still refuses to idle by itself unless I barely touch the pedal. I had it idling at 1000rpms for about 30 seconds with my foot touching the pedal. All the while it was putting the fuel out the tail pipe. Smell fuel very strong and then it loaded up the plugs. What company is the best to burn a custom order chip????? Thanks in advance.
99 7.3 towrig
13
01-02-2012 10:29 AM
GarageSpec
11-09-2011 09:10 PM
Centurion460
Computer Chips & Tuners
09-16-2004 01:15 PM
