Ford E350 5.4 liter Passenger Van Towing
I’ve not been able to find a 2006 E-Series brochure on line. Other sources suggest the OP’s E-350 passenger van is fitted with a 2V 5.4 V8 and a 4R100 four-speed AT. He’s already indicated that his van’s axle ratio is 3.73. Tire size is unknown. The mid-2000’s E-series 5.4 was rated at 255 HP @ 4500 RPM, and 350 lbs-ft torque @ 2500 RPM.
These specs may help assessing the OP’s configuration and offering performance-improving suggestions.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
I’ve not been able to find a 2006 E-Series brochure on line. Other sources suggest the OP’s E-350 passenger van is fitted with a 2V 5.4 V8 and a 4R100 four-speed AT. He’s already indicated that his van’s axle ratio is 3.73. Tire size is unknown. The mid-2000’s E-series 5.4 was rated at 255 HP @4500 RPM, and 350 lbs-ft torque @ 2500 RPM.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
I towed with vans for years.
The 5.4 was never a great towing motor. It needs to turn rpm to make power. So gearing is critical. 3.73s with taller than OE tires are creating much of your problem. Either shorter tires or shorting gearing or both.
The "chip" may actually result in less torque. I would try it without and see if it tows any better. I have heard good things about 5-Star tunes for these but have never tried one myself.
And have you had the catalytic converted checked? Its a common problem for the cats to become partially restricted and it kills the engines power, especially low rpm torque.
Drum-guy
16
07-12-2020 09:28 PM
Richard G.
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
01-14-2007 02:48 PM
cranes
02-22-2005 04:20 PM
nd48463
09-09-2004 04:37 PM
