Protecting Running Board Finish
If you want to use wood strips, composite, aluminum or whatever without drilling holes in the running boards 3M makes a double sided trim tape, one of the ones with the red backing, that will last probably for as long as you own the truck. It is the same tape they use for adhering moldings, trim badges and other trim on modern cars.
If you ever want to take it off a little mineral spirits or goof off will remove the adhesive and presto, like it was never there....
I picked up a Raptor Black Urethane Spray-On Truck Bed Liner Kit off of amazon.
Got it Thursday and sprayed it on Friday. Really like how it turned out.
nti Slip Tape , High Traction,Strong Grip Abrasive , Not Easy Leaving Adhesive Residue , Indoor & Outdoor, with Measuring Tape (1" Width x 190" Long, Black)
Another option could be the seadeck material to place on for shows. I wouldn't stick this to the running boards, unless they were the fiberglass ones, but you could just lay it on temporally. Quite a few colors and even a faux teak. This stuff holds up well in marine applications, lots of boats around here use it.
SeaDek Marine Products - Swim Platform Pads
Layed Out 100
02-27-2012 10:35 PM
tjdad62
18
10-17-2010 04:57 PM
billb7984
08-04-2003 04:47 PM
