1948 ford f1 transmission value
Old 04-15-2019, 11:04 PM
Dixon1948
Dixon1948 is online now
Dixon1948 is starting off with a positive reputation.
Can anyone me What is the value of my 48 f1 floor shifter trans? it was originally attached to a 6 cylinder it is a three speed. I'm switching to a 272 y block and no longer need the old transmission so I'm looking into selling it to get more parts for my truck
Old 04-16-2019, 04:32 AM
JPMallory's Avatar
JPMallory
JPMallory is offline
JPMallory has a great reputation on FTE.JPMallory has a great reputation on FTE.JPMallory has a great reputation on FTE.JPMallory has a great reputation on FTE.JPMallory has a great reputation on FTE.
3 speed or 4 speed?
Old 04-16-2019, 05:01 AM
Dixon1948
Originally Posted by JPMallory View Post
3 speed or 4 speed?
It is a 3 speed I'll go back and add it
Old 04-16-2019, 05:37 AM
pineconeford's Avatar
pineconeford
pineconeford is online now
pineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant future
Heavy duty T-87 3-speed (optional model) or the Light Duty 3-speed? One is more valuable than the other.
Tom
Old 04-16-2019, 06:19 AM
f5fordgirl
f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
Without seeing the gears and checking for teeth wear, especially the low rev slider, and the rev idler gear, and overall condition, its hard to say.
Old 04-16-2019, 07:03 AM
abe's Avatar
abe
abe is online now
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
Your data plate in your truck should tell whether it is light duty or heavy duty.
Old 04-16-2019, 08:48 AM
Dixon1948
where is that? is it in the glove box?
Old 04-16-2019, 09:03 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Not on a 48. They didn't have data plates like that, then. Detailed data plates were introduced in September, 1951.The only way to tell light from heavy is physical inspection. The heavy duty is similar in size to a 4 speed. The light duty trans is tiny in comparison.
Old 04-16-2019, 09:07 AM
abe's Avatar
abe
abe is online now
My bad! I didn't know that. In guess I should stick to questions about 53-56 trucks.
Old 04-16-2019, 09:08 AM
RiKi5156's Avatar
RiKi5156
RiKi5156 is offline
RiKi5156 is gaining momentum as a positive member of FTE.RiKi5156 is gaining momentum as a positive member of FTE.
Not to hijack this thread my 52 F-1 has a 48 HD 3 speed hooked to a 54 Mercury yblock. Rebuilding the trans and need to know what supplier I can get synchros,bearings and seals?
Old 04-16-2019, 09:24 AM
Dixon1948
it is tiny so i would assume it is a light duty
Old 04-16-2019, 09:50 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is online now
FortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud of
Check with Van Pelt Sales.
Old 04-16-2019, 10:38 AM
chriscris's Avatar
chriscris
chriscris is offline
chriscris is gaining momentum as a positive member of FTE.
Exactly correct. The case can also be worn to the point of scrap. Without inspection, $50-$100 would be expected. If it were inspected, with good gears, bearings, seals, synchro's and no case wear, I would say $300 ish MAX
Old 04-16-2019, 11:52 AM
Dixon1948
Ill have my dad look at it and tell me how good it is he has more experience with them
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
