Drum brakes/build thread - Help with another rookie mistake
Old 04-15-2019, 05:16 PM
tjeick
tjeick is offline
tjeick is starting off with a positive reputation.
hey guys in the zeal of my truck rebuild I took my drum brakes apart and chucked a few too many tiny metal pieces. Now frame and axles are painted and I need to begin re-assembly. These pictures are from last summer but now I have tax money so itís project time.
In this diagram, I am missing what I guess would be an anchor pin, the anchor pin plate, and to the left of that there is a pin in the wheel cylinder which other photos show on the right side. Luckily I still have the parking brake lever. But I am missing these parts, and I cannot find a part number ANYWHERE.
can anyone help?
Old 04-15-2019, 08:18 PM
mrollings53's Avatar
mrollings53
mrollings53 is offline
mrollings53 is gaining momentum as a positive member of FTE.
You'll probably have to hit up your local salvage yard for replacements. Here are all of the pics I took when I replaced mine a couple years ago. I'm guessing you have an F250/F350 based on the lack of a crumple zone on your frame.
Old 04-16-2019, 04:06 AM
tjeick
tjeick is offline
thank you! Those will be super helpful for when Iíve got all the rest of my parts together. Iím hoping to avoid a trip to the junkyard but you may be right.
Yeah sorry I forgot to mention. My truck was originally a 97 F-250. The axles I have are from an 87 F-350 cab & chassis dually. Same WMS-WMS but I had to move the spring pads.
i think I found the pins for the wheel cylinder on LMC truck. They are called a cylinder link and the part number I have is 45-3064
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
