1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
No rear running/park lights 2015 F250
Old 04-15-2019, 01:56 PM
66 bronco roadster
66 bronco roadster is offline
66 bronco roadster is starting off with a positive reputation.
My Ď15 F250 on my way home from my trip the rear running lights quit working. My brake and signal lights work but the taillights are out.
Which fuse should I look for? Iív looked online for the info but couldnít find anything.
Thanks in advance for your help!
Old 04-15-2019, 03:49 PM
Just Strokin
Just Strokin is online now
Just Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud of
you can download a searchable owner's manual here from Ford.....
Owners Manuals Search Results
Check Fuse 30 and 40 in the BCM.
Old 04-15-2019, 04:17 PM
66 bronco roadster
I checked fuse 30 earlier and it was ok and then just checked fuse 40 it to was good. Is it possible both lightbulbs went bad at the same time?
Anything else to look for?
Thanks!
Old 04-15-2019, 05:10 PM
66 bronco roadster
Ok I checked and replaced one of the bulbs... still no park lights.
Old 04-15-2019, 07:15 PM
Just Strokin
do you have park lights on front or on the mirrors?
Old 04-15-2019, 08:08 PM
66 bronco roadster
Yes I have park lights on my mirrors and the front. I even have the license plate light too.
Iíll look over the wiring diagram you sent me.
Thanks again, Jeff
Old 04-17-2019, 04:46 PM
66 bronco roadster
I found the culprit... it was a broken wire that the prior owner fixed (obviously not very well) that was taped up. After I cut off a 1/2 pound of electrical tape the broken wire fell right out of the butt splice.
With the correct size butt splice and fresh 3M electrical tape my truck has rear running light again!
Thanks for the wiring diagrams that really helped me narrow down the problem spot!
Jeff
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
