Something not so simple.. Assistance anyone?
Old 04-15-2019, 11:55 AM
CKF10068
CKF10068 is offline
CKF10068 is starting off with a positive reputation.
I was the unfortunate 'victim' of the theft of the original engine oil dipstick in my 1968 F100 (6.4 390) . I went back to the place in question, of course the young man is no longer working there (he had a 67 parked in the back). Went to check the oil last week, pulled out dipstick and it was obvious not the one that belongs (cut/squared bottom and no markings to register if oil was actually in pan). Long story short. I have scoured internet, called a couple of our parts yards, was directed to LMC, ordered, didn't fit (way too long). Any suggestions, websites, replacements? Thank you in advance.......
CK
Old 04-15-2019, 12:31 PM
seville009
seville009 is offline
seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.
This site comes up, but you’ve probably already seen it
https://www.npdlink.com/search/produ...0000&year=1968
Old 04-15-2019, 01:10 PM
lee
lee is offline
lee is starting off with a positive reputation.
Salvage yard near by?
Lee
Old 04-15-2019, 01:20 PM
Brian1971f100's Avatar
Brian1971f100
Brian1971f100 is offline
Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.
Best thing to do at this point is to file a reference mark on the dipstick at the current oil level.
Old 04-15-2019, 01:22 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by CKF10068 View Post
I was the unfortunate 'victim' of the theft of the original engine oil dipstick in my 1968 F100 (390) . I went back to the place in question, of course the young man is no longer working there (he had a 67 parked in the back). Went to check the oil last week, pulled out dipstick and it was obvious not the one that belongs (cut/squared bottom and no markings to register if oil was actually in pan). Long story short. I have scoured internet, called a couple of our parts yards, was directed to LMC, ordered, didn't fit (way too long). Any suggestions, websites, replacements?
C7TZ-6750-B .. Engine Oil Dipstick / 17 11/16" shield to full / 18 31/64" shield to add / 19 19/32" shield to full / Obsolete
1967 F100/250 2WD & F350 352 // 1968/74 F100/250 2WD & F350 360/390 // Ditto 1975 before serial number W00,001.
No Ford dealer or obsolete parts vendor has any, none on ebay.
Old 04-15-2019, 01:29 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
FuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to all
If someone would be so kind and get measurements from theirs you could then make the long one work.
I think for a start you need to where yours goes into the motor (I not up on the 390s) is it block, pan, timing cover as theirs will need to be the same.
Then from the stop "washer" at the top they measure how long it is and cut yours the same.
Then from the "washer" to the low & full marks and mark yours the same.
After that it should be good to go.
or
Cut the long one so it fits in to the "washer".
If you changing oil and it holds 5 qt with filter dump in 3qts and where it falls on the stick is the low 1 qt.
Now dump in the 4th qt and check and where it is on the stick is the full level.
Now if you dump in the 5th qt and start the motor to fill the filter, tune it off and give it time for the oil to make its way to the pan the level should be at the full mark.
Easy yes?
Dave ----
Old 04-15-2019, 01:45 PM
NumberDummy
Then from the stop "washer" (it's called the "shield") at the top they measure how long it is and cut yours the same.
See post #5. The Ford part number, applications and the various lengths from the shield are listed.
Old 04-15-2019, 06:17 PM
CKF10068
CKF10068 is offline
Thank you
Thank you for the specific information! Measurements are what I needed!!
Old 04-15-2019, 06:20 PM
CKF10068
CKF10068 is offline
Lee
Have called the "chain" around town (call one.. they say to call another and so on). No one local has one
Old 04-16-2019, 06:51 AM
lilorbie
lilorbie is offline
lilorbie is starting off with a positive reputation.
Man what kind of low life steals a dip stick.? Karma will get him for sure.
Old 04-16-2019, 02:04 PM
CKF10068
CKF10068 is offline
I have gone through (original +1) gas caps stolen also. People are great!!!
Old 04-16-2019, 05:41 PM
lilorbie
lilorbie is offline
CKF10068 this maybe bad to say ,but it,s how i feel. the more i am around "people" the more i love my dogs. to me the lowest forms of life are some one who steals and the other is a liar. that may not be P.C. but that,s just to bad. i have worked to hard for what i have just like i am sure others on this site have. but if you try to steal my stuff, you better hope that i do Not catch you.
Old 04-17-2019, 02:17 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
2X his comments!
Old 04-17-2019, 02:30 PM
CKF10068
CKF10068 is offline
It's not sad to say. It is more sad that it has to be said. I guess I shouldn't be shocked by people's behavior anymore. Still try to believe there are more good than bad, but sometimes its hard in situations like this. Geez. However, I am very appreciative of all the responses trying to help me rectify this situation.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
