Go Back  Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Reload this Page >
Thoughts going from 02 7.3 to 6.2 dually 4.30 gears
6.2L V8 Discuss the 6.2L V8
Old 04-14-2019, 09:38 AM
Heavy7.3
Heavy7.3 is offline
Heavy7.3 is starting off with a positive reputation.
I know I would not dare post this in the 7.3 section!! Lol but I'm really considering going to the gas side I researched enough to find out a 6.2 with 4:30 gears dually is more than capable of towing my camper and pay load ...
i just hope if I do it's the right decision with no regrets ..
currently I have a 7.3 crew lariat 145 on clock but starting to knickle and dime me I guess due to age biggest issue replacing oil pan , door well rust , up pipes etc
So I found a nice 12 f350 dually super cab 6.2 w/. 4.30 tow package with 80k miles XLT for asking $22,000
really clean good car fax all work done a dealer every 3k miles for oil change and brakes every year .
wife is pushing me to do this due her hate of the fumes and noise my 7.3 makes and needing to warm up in colder months ... thanks in advance on thoughts
Old 04-14-2019, 11:55 AM
00t444e's Avatar
00t444e
00t444e is offline
00t444e is gaining momentum as a positive member of FTE.00t444e is gaining momentum as a positive member of FTE.
How heavy is the trailer? The 6.2 with 4.30s will probably tow it just fine but keep in mind a gas engine needs higer rpms and will use more fuel towing the same load. When climbing a hill don't be afraid to let the engine run at 5-6K they are designed to do that.
Old 04-14-2019, 12:26 PM
Heavy7.3
Heavy7.3 is offline
camper is 9000 loaded bumper pull and atvs on bed so payload approx 2000 including water and fuel .. yea Im reading the 6.2 like high rpms with no problems
Old 04-14-2019, 05:01 PM
CrimsonRide
CrimsonRide is offline
CrimsonRide is starting off with a positive reputation.
The truck you are looking at will do anything your older truck will do and probably more. As stated be prepared for more shifts and higher rpm. This is not a bad thing as it used to be bc the newer trans dont heat up or wear with extra shifting imho. You can prevent the hard downshifts and rapid reving by staying off cruise and preparing for hills ahead of time by downshifting yourself and keeping it in a lower gear. My TT is 9000lbs and I have no pblms staying in 4&5 with occ 3s. Towing mileage usually in the 8s, day to day 12-14(max of 16s), lifetime combined is 12.7....good luck
Old 04-14-2019, 07:43 PM
ncl
ncl is online now
ncl is gaining momentum as a positive member of FTE.
With the 4.30 gears and having the smaller tires the duallys run. You wont see 5-6k rpm very often unless you're into it really heavy. It will pull that load up most big hills around 4k rpm ot maybe lower. A user on here called Rvpuller uses pretty much the same truck you are speaking of to pull a 15k 5er all around. 9k tt and some fourwheelers. Psshht. No problem. I pull a 10k 38 ft. TT with mine. 4.30 gears and it has no problem. I have a f150 with 4 30 gears and the taller 275/70/18 tires.
Old 04-14-2019, 08:34 PM
Heavy7.3
Heavy7.3 is offline
Thanks for responses I trying to make time to go look at it this week.. nothing really bad to say about my 7.3 but it's showing age biggest problem little rust and little slow but didn't get it to be a race truck major concern is reliability!!!!! I know 7.3 go to 500k miles but everything else not so much .. what are these 6.2 lasting so far since there debut in 2011 ??
Old 04-14-2019, 08:47 PM
don123's Avatar
don123
don123 is offline
don123 is starting off with a positive reputation.
A guy on here flatbed Ed had 418000 miles before major engine issues. Then he replaced the motor.
Old 04-15-2019, 05:39 AM
Chuck's First Ford
Chuck's First Ford is online now
Chuck's First Ford has a great reputation on FTE.Chuck's First Ford has a great reputation on FTE.Chuck's First Ford has a great reputation on FTE.Chuck's First Ford has a great reputation on FTE.
my 2012 F 250.... SCLB..... 6.2L Gas 167,000 miles....
I carry 1,500 pounds in bed of truck and Tow a 32 foot 9,000 travel trailer..
1,800 miles in 4 days several times a year.. for 4 years...
total rolling weight of 18,000 pounds... CAT scales....
no dually... just a little F 250. Gas.. does just fine.. NO 4x4... doing it with 3.73 gears and stock size wheels....
and this setup is LEGAL.... Tow and Camper package...
what you are asking a dually is EASY...
I know diesel guys hate RPM's the 6.2L overhead camshaft is designed to SPIN... so let it... 5k easy all day if needed up the mountains.
read my screen name..
when I needed a real work truck.. I got a Ford Super Duty... YES my first Ford Truck... 4 years and still happy with it.
retired Pro mechanic...
Old 04-15-2019, 08:05 AM
Heavy7.3
Heavy7.3 is offline
[QUOTE=Chuck's First Ford;18601299]my 2012 F 250.... SCLB..... 6.2L Gas 167,000 miles....
THATS a sweet set up and pretty close to what I need to haul... I'm glad to hear these 6.2's can haul and just let it spin .. I hear no complaints about the trans I guess pretty solid ??
Old 04-15-2019, 08:24 AM
CrimsonRide
[QUOTE=Heavy7.3;18601449]
16 or older gasser has same auto as diesel albeit diff tc and computer. A nice overkill to have imho.
Old 04-15-2019, 08:37 AM
Chuck's First Ford
[QUOTE=CrimsonRide;18601496]
’16 or older gasser has same auto as diesel albeit diff tc and computer. A nice overkill to have imho.
for people like me.. that does the homework. < research > the 6.2L 2011-2016 is a Real work horse... bar none.. my opinion.
F 250, F 350, F 350 Dually.....
I did not just do internet.. search.. I went to the fleet truck managers .. that were customers to my employer... ask them ...
for that class... Ford.
Old 04-15-2019, 12:56 PM
Ron94150's Avatar
Ron94150
Ron94150 is online now
Ron94150 is a name known to allRon94150 is a name known to allRon94150 is a name known to allRon94150 is a name known to allRon94150 is a name known to allRon94150 is a name known to all
If you YouTube "6.2 f250 4.88 towing", you will find a few of my videos, a couple towing 10k. My tire/gear combo will be very equivalent to a 4.30 dually. You want be disappointed.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
