thermostat question
Old Apr 13, 2019 | 07:08 AM
tree ape's Avatar
tree ape
thermostat question
i got up on a cold morning, started my 84 6.9. ran it for a few minutes, noticed the gauge went up to 180°. i shut it off and checked the top hose and the top of the radiator. they were cold. the heater hoses were hot.is this a thermostat issue?
Old Apr 13, 2019 | 06:37 PM
norm805's Avatar
norm805
Most of these thermostats don't start to open until 192 degrees .
Old Apr 13, 2019 | 09:07 PM
tree ape's Avatar
tree ape
thermostat question
ok, the stat is rated 192°. i get that. it just seemed weird that it reached 180 as quickly as it did. and it was a very chilly 30° morning. it usually needed around 10 mins to get up there. always seemed to take a while to pop.
i basically have reservations about the 190 stat. the po had a 180 in it ,and it worked just fine.
i replaced the h2o pump and the fan clutch last year.
Old Apr 13, 2019 | 09:28 PM
Macrobb's Avatar
Macrobb
Replace the t-stat with a Motorcraft one if it isn't. Aftermarket ones don't fit right/stick closed/break quickly.
Old Apr 14, 2019 | 09:39 AM
tree ape's Avatar
tree ape
thermostat question
it's a motorcraft. put in 3 yrs ago. probly IS sticking...
Eman1022
Mar 25, 2016 08:56 AM
NICKSAN
61
Dec 21, 2015 08:04 PM
jurban
Bronco II
Jan 4, 2010 06:57 AM
RyanJake
Feb 15, 2006 07:09 PM
hoxiii
Oct 7, 2004 01:35 PM
