1995 F250 dual tank fuel issue
Old 04-13-2019, 06:14 AM
ybshore
ybshore is offline
ybshore is starting off with a positive reputation.
I could use your help: I was called to jury duty so the wife and I switched vehicles for the week asn she was driving the truck. She pulled in yesterday after work and the truck sputtered to a halt and would not start again for her. When I returned, the truck has spark but no pressure at the rail. The dual tank switch is having no effect on switching tanks to make the truck run. Turnkey all her life, it's the first time the Ford has failed us. Question: is there a pump IN each tank? Guide me please! TY
Old 04-13-2019, 06:28 AM
ZombieF150's Avatar
ZombieF150
ZombieF150 is offline
ZombieF150 is starting off with a positive reputation.
Did you try to see if it was showing any codes? It will store codes without a CEL coming on.
Also here are some trouble shooting tips. https://easyautodiagnostics.com/ford...-relay-tests-1
Old 04-13-2019, 06:44 AM
ybshore
ybshore is offline
Q: is there one pump on each tank or is it one on the rail? TY
Old 04-13-2019, 07:06 AM
ybshore
ybshore is offline
As I try the tank switch, my fuel gauge is not responding. What may this be indicative of ? TY.
Old 04-13-2019, 08:48 AM
JJF20
JJF20 is offline
JJF20 is starting off with a positive reputation.
Yes. There is a pump in each tank.
Ive had the switch fail on me. I disassembled it, cleaned it, reassembled and it worked fine (dirty contacts). I’ve had the problem in other makes as well. New switch is cheap, changing it out is easy as well.
You could also also have a pump/sending unti failed. doubtful for double pump failure at same time.
Old 04-13-2019, 09:03 AM
subford's Avatar
subford
subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
First off check the Inertia fuel shut off switch. Push the red button on top down to reset it.
The Inertia switch is located in the behind passengers kick panel. There should be a hole in the panel for resetting it.
Dose the selected fuel pump now run for one second each time the key is turned to the run position?
Your fuel system:
Old 04-13-2019, 09:22 AM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Empty fuel tanks.
Old 04-13-2019, 09:38 AM
ybshore
ybshore is offline
Not...wish....
Old 04-13-2019, 10:21 AM
subford's Avatar
subford
What does the fuel gauge needle point to when the key is turned to the run position?
Not...wish....
Are you also saying that the selected fuel pump will not run for one second each time the key is turned to the run position after pushing down on the Inertia fuel shut off switch?
If so short pin #2 to pin #6 of the self-test plug and turn the key to the run position. Does the selected pump run all the time now?
If not ground pin #6 of the self-test plug and turn the key to the run position. Does the selected pump run all the time now?
Old 04-13-2019, 10:42 AM
ybshore
ybshore is offline
The gauge is reading 3/4 in both tanks EXACTLY in not moving and I know one is about 1/2 and one is near full.
Old 04-13-2019, 10:53 AM
ybshore
ybshore is offline
Thanks so much for the guidance. Heading out to the barn to inertia test her...what would your sequence be for troubleshooting the matter? TY.
Old 04-13-2019, 10:55 AM
ybshore
ybshore is offline
How does the **** come off the headlight switch?
Old 04-13-2019, 11:01 AM
subford's Avatar
subford
Old 04-13-2019, 11:06 AM
ybshore
ybshore is offline
I meant by not responding that it was staying at 3/4 with no movement via switch. Sputtered.
Old 04-13-2019, 11:07 AM
ybshore
ybshore is offline
I also note there is no pressure at the rail, even after cranking
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
