1995 F250 dual tank fuel issue
Old 04-13-2019, 11:09 AM
ybshore
ybshore is offline
ybshore is starting off with a positive reputation.
AWESOME. TY.
Old 04-13-2019, 12:04 PM
ybshore
ybshore is offline
Appreciate that.
Old 04-13-2019, 03:04 PM
ybshore
ybshore is offline
Here's our beast: just hit 100k....
I accessed the inertia button at pass. kick which does need seem to 'move' up or down...no click or the like. I do not hear the pre-load with key on/off.
I have also accessed the fuel tank switch via dashface which 'seems' undisturbed.
Old 04-13-2019, 04:54 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Check that there is power at the main PCM and fuel pump relays, these should both click when the key is first turned to the run position but if the PCM isn't getting power the fuel pumps will never be energized.
Old 04-13-2019, 04:56 PM
ybshore
ybshore is offline
Where are the relays? TY
Old 04-13-2019, 05:06 PM
subford's Avatar
subford
subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Old 04-13-2019, 05:09 PM
ybshore
ybshore is offline
Awesome AGAIN! Headin' out after dinner..........
Old 04-14-2019, 08:26 AM
ybshore
ybshore is offline
Found fuel Pump Supply 20A fuse blown. Heading to parts shop for same. What would would be a cause of such? TY.
Old 04-14-2019, 11:19 AM
subford's Avatar
subford
Maybe this will help:
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
