2015+ F150 Discuss the 2015 Ford F150
2016 F150 Ecoboost 3.5 P0420 and P0430
Old 04-15-2019, 10:03 PM
reamer's Avatar
reamer
reamer is offline
reamer has a great reputation on FTE.reamer has a great reputation on FTE.reamer has a great reputation on FTE.reamer has a great reputation on FTE.
Ford390
Is that a photo of a plug close-up?
Thanks
Old 04-16-2019, 09:09 AM
smokewagun
smokewagun is online now
smokewagun has a good reputation on FTE.smokewagun has a good reputation on FTE.
Originally Posted by ford390gashog View Post
My thoughts are the life of the cats have been severely reduced. The reduction of ZDDP and phosphorus in SN oil is to combat the destruction of palladium used in modern systems but isn't really meant to deal with that much oil consumption.
Thank you gashog.
Old 04-16-2019, 09:41 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
Originally Posted by reamer View Post
Ford390
Thanks
Yes that is a very close up image of a spark plug with less than 30k on it. That carbon tracking is from a micro crack and causes the spark to jump and leak through the boot to ground. This is why boots are a replacement item and to be very careful not to side load a spark plug when installing them and change them every 60k. Some of us do 30k because the gap has changed so much.
Old 04-16-2019, 09:50 AM
smokewagun
So, should a guy put anti-seize or something else on the plugs if we are removing them frequently? Id hate to be fighting plugs ever 30,45,60k.
Old 04-16-2019, 10:21 AM
GlueGuy's Avatar
GlueGuy
GlueGuy is online now
GlueGuy has a great reputation on FTE.GlueGuy has a great reputation on FTE.GlueGuy has a great reputation on FTE.GlueGuy has a great reputation on FTE.
When I had my airplane, I always used anti-seize on the plugs, but there were serious heat considerations in an aircraft air-cooled engine. I can't imagine that it would be ill-advised, but I honestly don't know. Look forward to hearing from someone on the list who might be familiar with any potential issues.
Old 04-16-2019, 01:14 PM
bwep
bwep is offline
bwep is gaining momentum as a positive member of FTE.
My 2013 started throwing the PO 430 code. I reset the code multiple times. It would take between 20 to 70 miles before it would return. My mechanic friend told me replace both O2 sensors first. Said testing the O2 was a waste of time, too many variables. He said they should be replaced as a pair because they communicate back to each other, if one is off the code will trip. Well replaced the 2 on the driver side (code indicated that side) did a Kam reset and have put on 12,000 since and no code. I think this should have been your first step. Good luck.
Old 04-16-2019, 03:53 PM
GABAR's Avatar
GABAR
GABAR is offline
GABAR has a good reputation on FTE.GABAR has a good reputation on FTE.GABAR has a good reputation on FTE.
But the EcoBoost can't run 100k on plugs that's well known. They just low grade misfire and burn the cats out. General consensus here is every 60k with boots. The smallest carbon tracking will cause misfires. There was a TSB for all 3.5 engines built prior to 2014. Below is the carbon tracking condition
Very interesting and thanks for the info because I had no idea about the TSB.
Old 04-16-2019, 08:34 PM
poofyo101
poofyo101 is offline
poofyo101 is starting off with a positive reputation.
While driving today. The CEL went away. No longer showing on the dash. It was for the p430 for the left cat. Would you guys suggest changing the plugs and boots and seeing if the code comes back? Or just go ahead and change the cat also?
Old 04-16-2019, 10:09 PM
ford390gashog
Plugs are to be coated in Motorcraft XL-2 nickel anti-seize apply lightly to the threads.
Old 04-16-2019, 10:14 PM
ford390gashog
Only change the plugs and boots, avoid the CAT for now.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
