Disconnect the hose to the IAC while running and put your hand over both the IAC port, and the hose and see if it goes away. My V10 was a little loud in the "sucking" since brand new
I've never heard another v10 running or even at idle so idk if maybe it should sound like that and you said yours sounds like that from brand new thanks I'll try that tomorrow and see what happens.
But yeah, my V10 did have a good suction sound to it all it's life. I can't say it's as LOUD as yours or not...
krewat would you mind if I email you a video of the motor running maybe you can tell me if its suppose to sound like that or not. I can't load a video here idk why. pm me
Yeaa I went threw 3 new iac's thinking they were ****. And I don't have a check engine light or pending codes. It only does that little shake once in awhile at idle
