Truck won’t start with key, only if I jump the solenoid
I just recently put a reman C6 trans in my 89 f350 7.3 and for the first day everything was fine next morning the key wouldn’t turn over the truck so I jumped the solenoid and decided to deal with it later,now the little gear indicator won’t go into p,when it is in park and I have to manually jump the solenoid everytime,replaces the solenoid and took the neutral safety switch off and adjusted it every way possible and nothing.and ideas?Thanks
Check that the trigger wire is getting power with the key in start with a test light or check the continuity, which ever you prefer. If that fails, remove the ignition cylinder and check for power and proper connections. If the checks out, I would investigate what, if anything, the PRNDL has to do with the function of the system.
The gear indicator doesn't have anything to do with your transmission. It's just a little cable that goes from the column shifter to under the dash. It's adjustable if you take the bottom of the column off. It passes through a tube and sometimes they can get sticky in there.
While you're in there, test your ignition switch.
Could be the neutral safety switch, but I'm more inclined to believe that your ignition switch failed and the shift indicator made you think neutral safety.
But before you do any of that. I would pull the codes, and see if it isn't sometime different all together.
Received 3,102 Likes
on
on
yes I feel it spring back, I replaced the tumbler a couple months ago because the key was really hard too turn, no problems with it after till the new tranny was in
on
check the wires going to the nss.
it could simply be a broken wire or bad connection.
also, reach up under the dash. feel along the top of the steering column about above the brake pedal for the ignition switch. it may be separated.
the switch is half aluminum, half plastic. when the two parts split open all sorts of funky electrical issues appear out of the blue.
Just a thought, but retest that new solonoid. Just because you replaced it with a new part doesn't mean its working correctly. If your still jumping it across to start then first one wasn't bad or they both are. . Been there and done that. We were about to flash a pcm a couple weeks ago and turns out it was a "NEW" coil pack on 06 mustang. Second coil pack in a week and purrs like a kitten now. Worth the second look.
markeyd
02-21-2016 07:32 PM
SwampFox112
13
11-14-2015 06:18 PM
TheMonkey
09-30-2012 06:21 PM
mounddog
20
08-09-2008 09:31 PM
