Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L high oil temps after NEW oil cooler
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 04-26-2019, 05:51 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Last year a friend of mine has a shop and had the same thing happen with a lifesquad they were working on. They changed the oil cooler, and was fine for a 100 miles or so, then it would start running hot. Oil cooler was plugging up. Turns out some dip**** at the firehouse poured some radiator stop leak in it to "fix" the notorious radiator leaks that these trucks are known for. In a nutshell, they changed the oil cooler 5 times before it was cured. Pulling the hoses off, flushing the radiator got some of that schit out, but the oil coolers caught most of it.
Old 04-27-2019, 08:47 AM
Ian123's Avatar
Ian123
Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
Originally Posted by bummoose View Post
Okay, next week we will be doing a coolant change oil change over to synthetic checking the thermostats. Couple questions, first off going to synthetic what oil do you recommend.
Also was thinking about going with an external add-on external oil cooler but having a hard time finding one any suggestions?
Thanks for the help
My buddy was having the same issue as you, he installed one of the external oil coolers and it helped his temps when towing but he can't idle his truck for too long now or it will overheat
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
