Road crown and drift
Old 04-06-2019, 10:17 PM
palacios289
palacios289 is offline
palacios289 is gaining momentum as a positive member of FTE.
Agreed. Iím actually going to drive to fabtech. I happen to work a block away from the kit HQ and warehouse. Letís see what they say.
Old 04-06-2019, 10:41 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is online now
pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.
That should take any guess work out of it, I gotta believe whom ever their current engineer is will have the answers.
Old 04-08-2019, 04:53 PM
palacios289
Pirate, I pulled this pic from google. look at how much more parallel the link is to the I Beam.
Old 04-08-2019, 06:42 PM
pirate4x4_camo
Hard to make a total assessment without seeing the whole thing but that certainly looks better then yours.
Old 04-08-2019, 07:41 PM
palacios289
Pirate, that’s a stock height excursion.
I spoke to fabtech. They never had any bumpsteer issues with this kit. (Sure!!). Their recommendation was to double check alignment. I asked how can the same pitman arm be used on both the 4 and 6 inch lift. The pitman according to fabtech is a 3 inch drop. My question was how can that be ideal for both drops. It would seem it would be a compromise for both drops or ideal for 4 inch lift and borderline with 6 inch. Tech had no response for this.
Would more caster than factory induce bumpsteer?
Old 04-08-2019, 11:30 PM
pirate4x4_camo
I don’t know enough about the geometry of Y link steering and twin I beam suspension to have that answer but you could make that statement about a soiled axle setup because the reason ypu drop those is to have enough angle for the ball joints in the tie rod. It on the twin I beam you have a whole another set of arch’s going sideways plus a crazy unequal length Y tie rod to consider so hmmmm.
No, caster is not nor can not cause bump steer.
and yes... I gathered from the bump stop to beam clearance it was stock.
Old 04-15-2019, 05:08 PM
palacios289
UPDATE
I have an update. I ended getting a killer deal on brand sparking new fabtech radius arms. Swapped those out yesterday and took the truck to an alignment. Most of the bump steer is gone with very very light drift. See the alignment specs below. Any thoughts?
Old 04-15-2019, 10:31 PM
pirate4x4_camo
Before I digest the alignment what did I miss , Why did you need new radius arms ?
Old 04-15-2019, 10:53 PM
pirate4x4_camo
Basically they changed your TOE OUT from -.03* to -.08 Like I said before, I am not well versed in the Ex RWD front suspension but I would want mine setup with +.03* TOE IN
The Ford Factory manual shows the spec as +.03* Toe in but + or - .25* so technically toe out would Ben within spec but me thinks it would be squirrelly with toe out.
Fwiw....the 4x4 Ex works best with +.03 to .06* TOE IN and as you can see they have the same toe spec.
Old 04-15-2019, 11:03 PM
palacios289
Thanks pirate. It didnít need new ones other than for cosmetics. The ones I got were painted an ugly red by previous owner. I got a steal on these brand new ones so I jumped on them.
Old 04-15-2019, 11:51 PM
palacios289
Pirate any issues with my caster at 6.7 and 8.3? Would adjusting the toe in effect the caster and camber?
Old 04-16-2019, 12:08 AM
pirate4x4_camo
Caster spec is 4* +/- 2 So let’s say a max of 6*
8.3* is a heap of caster but other then heavy steering at parking lot speed it isn’t going to hurt anything.
adjusting caster/camber affects toe but you can change toe without affecting caster/camber
I would start by fixing your Toe, Have them change the toe out to .+03* toe in,
Toe In is +
Toe out is -
  #28
Old 04-16-2019, 12:48 AM
palacios289
Sounds good. I’m going to have them adjust the toe to the specs you posted. Just the change today did help the bump steer issue.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
