so I have acc power lights fan radio etc, however I have no sign of crank solenoid doesn't actuate no starter noise no nothing... any ideas??
(replaced plugs, plug wires, coil, battery and starter solenoid)
On my '68 the nss is at the base of the steering column inside the truck. Short the 2 wires together to bypass it. Mine failed in the '70s and I haven't had one on it since. Connect a 12v jumper from the battery to the s terminal of the solenoid and see if it cranks. You'll have to turn the key on first.
It was the nss I just held the shifter up a little more and it cranked... (Thanks everyone for your help)
