Sponsored by: Real Truck
Bad PCM?
Old Apr 2, 2019 | 12:59 PM
Rivieraman71's Avatar
Rivieraman71
Bad PCM?
Truck is a 99 7.3 6 speed. So I was looking for a bad ground in relation to my speedometer not working. I disconnected the ground on the inner drivers side fender and turned the key on to start checking and reconnected it. Ever since doing that the truck won’t start. Fuses are good, relays are good and 12v going to all the fuses but only 5-6 volts going to the fuel pump. No service engine soon light or wait to start and my scanner won’t connect to the computer. Hooked the fuel pump directly to the battery and it comes on but the truck still won’t start. Also only .3 volts going to fuse #20.
Old Apr 2, 2019 | 05:30 PM
projectSHO89's Avatar
projectSHO89
Sounds like the PCM is not powering up.
Old Apr 2, 2019 | 07:58 PM
Rivieraman71
Went to a few places today to ask about the problem and they think it’s a definite ground problem.
Old Apr 8, 2019 | 09:07 PM
Rivieraman71
Wound up being a bad EBP sensor
Kahuner
Nov 23, 2013 07:40 PM
jeffreyt
43
Oct 9, 2013 02:11 PM
rwdfan
Feb 21, 2012 09:53 PM
SpoolingV8
Oct 10, 2007 08:23 AM
tim73
Electrical Systems/Wiring
May 26, 2006 08:19 PM
