460 Swap
Old Mar 29, 2019 | 10:44 PM
armedforcesracing's Avatar
armedforcesracing
460 Swap
1971 F100 with the stock 302 and C4 and will be swapping in a 1970 460 with a C6. Who has the part numbers I need for this engine swap? Google has not been my friend on this.
Old Mar 29, 2019 | 11:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Upper pic: You need 1973/79 F100/350 460 R/L engine supports (6028/6029), rubber insulators (6038), R/L brackets that bolt to the block that the insulators bolt to (6030/6031).
Rear engine support bracket (6A023) and rubber insulator (6068).
1968/78 Passenger Car & 1975/97 Econoline 460 engine mounting parts will not work, neither will 1983/97 F250/350 460 engine mounting parts.
You will also need a reverse sump oil pan and pickup tube, the special main cap bolt the pickup tube bolts to. 1975/97 Econoline 460 use these parts.
All these parts are also available aftermarket.
Old Mar 29, 2019 | 11:42 PM
armedforcesracing
Do you have a source for these parts?
Old Mar 30, 2019 | 12:38 AM
RichS2659's Avatar
RichS2659
Autofab is one source:
https://autofab.com/c-335578-heavy-d...truck-2wd.html
Old Mar 30, 2019 | 08:39 PM
armedforcesracing
Originally Posted by RichS2659
Thanks for that link! They have a lot of mounts for my future builds and projects as well!
bsneed
Dec 28, 2016 01:29 PM
74f250USMC
Jun 30, 2014 01:09 PM
beast908677
Apr 5, 2012 10:16 PM
dyingtolive
19
Jan 31, 2012 06:37 AM
Boz Turner
Sep 29, 2009 06:28 PM
