Beehive Oil Filter
Old 03-27-2019, 12:59 PM
Suffolkman's Avatar
Suffolkman
Suffolkman is offline
Suffolkman has a good reputation on FTE.Suffolkman has a good reputation on FTE.
This morning I ordered a replacement filter (the same as the one I removed). This is not the filter number that is mentioned everywhere as fitting Beehive type filters. I just looked at the spec of this common filter (the same as fits the Speedway types. On measuring my case...that filter would not fit in. It is just to wide in diameter, and the inside hole diameter is to small to fit over the central pin. Perhaps it is an original. Whilst waiting for the replacement filter to arrive I might remove the case from the truck and try to identify it.
Suffolkman
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
