My centurion cc f150 project
  #121
Old 04-17-2019, 12:14 AM
fordman67's Avatar
fordman67
fordman67 is online now
fordman67 is a name known to allfordman67 is a name known to allfordman67 is a name known to allfordman67 is a name known to allfordman67 is a name known to allfordman67 is a name known to all
Originally Posted by skuzzybucket View Post
Nice set of 3 bar explorer heads would look purrrdy on there too, and wake that little small block right up. & a set of 1.7 roller ped mount rockers
Just saying
https://www.ford-trucks.com/forums/1...p-busy-ot.html
Check that old thread of mine out
  #122
Old 04-17-2019, 06:31 AM
skuzzybucket's Avatar
skuzzybucket
skuzzybucket is offline
don't play well w others
skuzzybucket has a spectacular reputation.skuzzybucket has a spectacular reputation.skuzzybucket has a spectacular reputation.skuzzybucket has a spectacular reputation.skuzzybucket has a spectacular reputation.skuzzybucket has a spectacular reputation.skuzzybucket has a spectacular reputation.skuzzybucket has a spectacular reputation.skuzzybucket has a spectacular reputation.skuzzybucket has a spectacular reputation.skuzzybucket has a spectacular reputation.
Nice!
I built the similar motor for the 94 pickup, but used the 3 bar head, the plugs are still angled on those.
I also used a different cam for more bottom end.
. still, it's only a 5.0.
  #123
Old 04-17-2019, 10:58 AM
fordman67's Avatar
fordman67
Nice!
Uh the 3bar gt50s don't have the dumb angle of the p I thought?
I was disappointed but honestly I never put more timing in it or checked a/f. The mustang cam in the heavy SUV might have not been ideal . The mustang cam is small tho.
I should have kept that bronco. It was so very nice and rust free.
Trying to find the motivation to go stab the mill back in...
  #124
Old 04-17-2019, 02:42 PM
skuzzybucket
3 bar heads have same combustion chambers, but the spark plugs are angled like efi heads, NOT straight in like the p heads, so they don't require special exhaust.They also don't have the chamber going through them for the A.I.R. pump, so no smog
1.7 roller rockers will give you some "cam" with the stock cam for about $100.
Mustang cam comes alive about 3 grand, trucks need the grunt, so you need bottom end. If you decide to build a 5.0, or 5.8 to play with in a truck, let me know, I have a few I played with ,and figured it out pretty good.
Even Tom listened to me on one of his 5.0 toys ( not that he will admit it)
  #125
Old 04-17-2019, 06:22 PM
fordman67's Avatar
fordman67
Oh, yea you are correct. I forgot about those.
Well as of about 5 today It is alive. I ran it and got the coolant,ps,oil topped off and it moved it's self out side. Later I'll take it for a test drive maybe.
  #126
Old 04-17-2019, 08:22 PM
skuzzybucket
Cool. I like that truck. Would look good next to my Centurion Bronco. LOL
Oh, and that one is a C-350, it has a 460 in it.
  #127
Old 04-17-2019, 08:59 PM
fordman67's Avatar
fordman67
some gnarly ol' freeze plugs
all back in. This was earlier today . I didn't get a completed pic but will tomorrow. It's running well and the wife and I went for a test drive earlier.
Winning boys!!
Tomorrow seat mod and a driver's mirror swap. Clifford giving up old unused parts...
  #128
Old 04-17-2019, 10:25 PM
fordman67's Avatar
fordman67
A nice LOW 2wd 4door bronco would be BA😁
I'd totally rock that!
  #129
Old 04-18-2019, 12:54 AM
Tim Young's Avatar
Tim Young
Tim Young is offline
Tim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputation
Looking good, your going to have a great daily driver!
  #130
Old 04-18-2019, 09:03 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Jarrett Campbell is gaining momentum as a positive member of FTE.Jarrett Campbell is gaining momentum as a positive member of FTE.
Now that it's working and reliable,
TURBO TIME
  #131
Old 04-18-2019, 09:22 AM
fordman67's Avatar
fordman67
A couple of things then it's time to work on Clifford!!! Thanks fellas, I am pretty happy to have grandpa to close to 100% .
  #132
Old 04-18-2019, 01:34 PM
fordman67's Avatar
fordman67
all like new! On to other fun projects!
  #133
Old 04-18-2019, 02:51 PM
skuzzybucket
Very nice!
Only thing I can see might bite you later is the vacuum juice can on the fender. It may or may not have rust holes in the bottom, Mine did when it got looking like that.
You'll know when you have your a/c on, and hit a hill, it goes to defrost as default
Grab one from a 93-96 5.8 truck, they're plastic
Also, lookin at your master cyl, you don't have the cruise control fuse recall. take your serial number over to ford, make sure, there is a pig tail harness with fuses that goes in there to keep gramps from catching fire
  #134
Old 04-18-2019, 03:45 PM
Jarrett Campbell
If that pigtail is the same on 3/4 ton trucks, I have one in my parts bin.
  #135
Old 04-18-2019, 04:44 PM
fordman67's Avatar
fordman67
Very nice!
Lol, it's scheduled at the dealership for tomorrow at 1:15!!!
Yea it's needing done. There is no fluid intrusion that I can see so it's ok till tomorrow.
Drove it all around today and it is very well. Pulled the front seats and did some improvement.
https://www.ford-trucks.com/forums/1...-seat-fix.html
Just like that we did all along
Sits even better
Next a driver's side mirror, machine front rotors and swap in the LSD I have sitting here. I planned it for the falcon but that's gone and I need a pair of tires turning lol
#because5literpowa
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
